path constraint
hi, guys max default path constraint is so faulty and it has so much weakness please scriptwriters write a script that we label drive an object on the path with other linked to the parent's object and flipping issue add more function like we able clone the objects on the path.
thank you so much
TsveTan's picture
Its not so bad, but is not appropriate for cars animation, because realy only the wheels direct the path shape tangent and body direction should be calculated...so its for simple tasks. On other hand the not constant velocity property is very useful, so basically it depends on the project. If u provide more info maybe I can give you hint.
