access texturemap from VRayDirt
By senisleft · 2013-10-15
Hi I have a problem for getting texturmap from vraydirt that already inside some object.if i using $.material.diffusemap.vraydirt.texmap_occluded_color.bitmaptexture.filename
it result error Unknown property: "texmap_occluded_color" in .
I would be realy greatfull if someone could help me to solve this problem since i have so many material i have to change.
Comments (21)
Nice one, It works thanks a lot guys its save my time :D
Budi G · 2013-10-16
My pleasure :)
"collect all DIRT maps from selected objects"
barigazy · 2013-10-16
Ok.
In order to collect all VRayDirt Maps on the scene we can use
getClassInstances VRayDirt
But that is easy. Now answer for the post title :
--collect all DIRT maps from selected objects FN
fn getDirtOf objMtl &inTrashCan =
	for m in (refs.dependsOn objMtl) do
		case (superclassof m) of
			material: getDirtOf m &inTrashCan
			textureMap: if isKindOf m VRayDirt and (for t in inTrashCan where t.name == m.name collect m).count == 0 do append inTrashCan m
-- Select some objects and run next
dirtMaps = #() -- here we collect all dirt :)
for obj in selection where obj.material != null do getDirt obj.material &dirtMaps
dirtMaps -- result
-- Now when the trash can is full we can do whatever we want
for dm in dirtMaps do
	format "vrDirt Name : %\n" dm.name
	format "\tObjects : %\n" (for n in (refs.dependentNodes dm) collect n.name)
	for p in getPropNames dm where isKindOf (gp = getProperty dm p) textureMap do
		format ("\t" + toUpper (p as string) + " : %\n") gp
-- etc.
Hope this is not too difficult to understand
;) Cheers!
Budi G · 2013-10-16
Branko
run your script , got an error ...
- What is the value of 'null' ?
- You don't have getDirt() function, probably mean is getDirtOf() , is it right ?
Yup getDirtOf(). I changed name of fn but forgot to change in for-loop.
null is undefined variable. U can put any word or simple use predefined 'undefined'
-- now select some objects and run next
dirtMaps = #()
for o in selection where o.material != undefined do getDirtOf o.material &dirtMaps
dirtMaps
Budi G · 2013-10-16
ok, now a script works,...sound good.
hmm in this case you just collect the vray dirt map, not the filename as he need.
such as:
format ("\t" + toUpper (p as string) + " : %\n") gp.filename
and it will be better to need more filters because the vray dirt map can apply to standard material or multi material.
btw about standard material, is a different method than vray material if we use this methods.
This supports any type of material. And I placed "--etc." at the end, so you can add below that anything even to look for filenames. Also in some cases users not use only bitmap textures but other procedural maps.
The main problem is to collect VRayDirt maps from selected objects materials and after that everything is easy. :)
Now next step is to collect all bitmap textures which are directly asigned to VRayDirt maps slot, or indirecty (combined with procedurals)
Now is your turn, Budi :)
The next solution can be related not only to VRayDirt map but any other map type.
As U see I used *superclasses not *classes that why I not needed more filters
Best way is to use RECURSIVE FN.
I already posted a solution how to collect all nested bitmaps on this forum
Get all Vray Dirt Maps Filename
Budi G · 2013-10-17
Yup, Recursive functions can be faster.
(--start
    fn GrabAllMaps mat arr =
		if mat.numsubs != 0 then (
			for i = 1 to mat.numsubs do (
				if mat[i] != undefined then (
					if classof mat[i] == SubAnim then (
						if superclassof mat[i].object == textureMap then (
							if mat[i].object != undefined then append arr mat[i].object
				GrabAllMaps mat[i] arr
	) -- This function taken from BlurScripts by Neil Blevins, I found in ColinScripts a few years ago. ( Thanks for Them )
  fn GrabVdirtMaps mat =
     if mat != undefined then
        local AllMaps=#(), VrayDirtMapFile=#(), x,p
	    GrabAllMaps mat AllMaps
		for x=1 to AllMaps.count where (classof AllMaps[x])==VRayDirt do
		  for p in (getPropNames AllMaps[x]) where superclassof (prop = getProperty AllMaps[x] p) == textureMap do append VrayDirtMapFile prop.filename
	   VrayDirtMapFile
   --------------------------------------------------------------------- execute as example
   for obj in selection do print (GrabVdirtMaps obj.material)
)--end
barigazy · 2013-10-17
Yup. Thats the one. I used this fn a couple of times but when the scene is complex (with many textures) then is also very slow.
We can optimize this a bit more but requester not asked for more. So... :)
Regards!
Budi G · 2013-10-17
oh, it's Ok Branko...
I hope to see you to optimize this method. If you don't mind :)
I just think it could use a INI file or xml to handle Memory allocation.
barigazy · 2013-10-18
Ok. I have a suggestion.
Open new thread and then we can start a discussion about universal solution (fn) which can be related to any map or material type.
First we have to setup basic concept (what we need to do in order to solve the problem) without snippets.
This fn must found all fileNames in (Bitmap, VRayHDRI, VRayBmpFilter etc.) of specified map class (VRayDirt, Noise, Composite, ColorCorrection etc.) assigned to the any material (Standard, VRayMtl, Arch&Design, Blend, Multimaterial etc.)
Also are we need to consider only selected objects or whole scene
Uh... :)
Are you agree?
agreed :)
Budi G · 2013-10-19
ok, I open new thread Here
btw sorry if I long to comment because there is something I have to do.
Budi G · 2013-10-15
Hi..
try this one
You don't need to write 'vraydirt' and 'bitmaptexture', such as:
$.material.diffusemap.texmap_occluded_color.filename
barigazy · 2013-10-15
If you have many objects and you want to collect all maps in VrayDirt map then
u can try this. Also this works only if dirt map is in diffuse slot of VRayMtl
fn findDirtMaps obj = if obj.material != undefined do
local props = #(#texmap_radius, #texmap_occluded_color, #texmap_unoccluded_color, #texmap_reflection_glossiness)
if isKindOf (mtl = obj.material) VRayMtl do
if isKindOf (dirt = mtl.texmap_diffuse) VRayDirt do
for p in props where (map = getProperty dirt p) != undefined collect map
findDirtMaps $
Function will be more complex if you need to support different material types and any map slot.
Budi G · 2013-10-15
If you can understand the script from barigazy, it is good to be applied.
Hey Budi
how about more complex solution ei. "collect all DIRT maps from selection". :)
Post if you have something and we can talk about
I have this one
Budi G · 2013-10-16
This is Collect v dirt of diffuse map only
( -- start script
local VdirtMapsCollection =#() -- Init
fn getVdirtMapFilename diff =
	local map_filename=#(), propname, prop, map
    if classof diff == VRayDirt then
      propname = getPropNames diff
      for prop in propname do
	    map = getProperty diff prop
        if classof map == Bitmaptexture then
        ( if map !=undefined then if map.filename !="" then append map_filename map.filename )
	map_filename
) -- fn
  if classof mat == Standardmaterial  then
    if classof mat.diffusemap == VRayDirt then ( VdirtMapsCollection += getVdirtMapFilename mat.diffusemap )
  ) else
	if classof mat == VRayMtl  then
		if classof mat.texmap_diffuse == VRayDirt then ( VdirtMapsCollection += getVdirtMapFilename mat.texmap_diffuse )
	) else
		if classof mat == MultiMaterial  then
		  if mat.numsubs != 0 then for index=1 to mat.numsubs do (GrabVdirtMaps mat[index])
) -- fn
   ----------------------------------------------execute
   GrabVdirtMaps $.material
   --clearlistener()
   VdirtMapsCollection -- this is All Collection of Vray dirt
) --end script
do you want optimize it ? :)
fn findDirtOccludedMap obj =
if isKindOf (tex = dirt.texmap_occluded_color) Bitmaptexture do
format "bitmap = %\nfilename = %\n" tex.bitmap tex.filename
findDirtOccludedMap $
Budi G · 2013-10-15
oops.. I think I'm late than you .. heheh
