assign files from folder to material
By sven · 2014-03-07
sorry for my bad english, it´s not my native. I need your help. i need a script todo the following.
i have 5 folders with around 40-50 textures, in every folder is a seperate file too, this file is used as bump map. I have a objectgroup in the scene. I build this script, parts are here from the forum, thx miauu
global rol_worwhite
try(destroyDialog rol_worwhite)catch()
rollout rol_worwhite "miauu"
local matDir = undefined
local bumpFile = undefined
button btn_browsebump "select bump map"
button btn_browse "select folder with textures"
button btn_render "RENDER" enabled:false
on btn_browse pressed do
dir = getSavePath caption:"select folder with textures"
if dir != undefined do
matDir = dir
btn_browse.tooltip = matDir
btn_render.enabled = true
on btn_browsebump pressed do
file = getOpenfileName caption:"select bump map"
if file != undefined do
bumpFile = file
btn_browsebump.tooltip = bumpFile
btn_render.enabled = false
on btn_render pressed do
local curObj = getCurrentSelection()
local matFiles = getFiles (matDir + "\\*.jpg")
local scenename = getFilenameFile maxfilename
renderSceneDialog.close()
selectedCamera = viewport.getCamera()
local originalOutPath = rendOutputFileName
for m = 1 to matFiles.count do
curObj.material = standardMaterial diffuseMap: (Bitmaptexture fileName:matFiles[m]) showInViewport:true
texturename = ( getFilenameFile matFiles[m])
cameraName = selectedCamera.name
outputPath = (getfilenamepath originalOutPath) + ( getFilenameFile(filenamefrompath originalOutPath)) + "_" + scenename + "_" + cameraName + "_" + texturename + "_" + (getFilenameType originalOutPath)
rendOutputFileName = outputPath
rendSaveFile = true
rendShowVFB = false
max quick render
createdialog rol_worwhite
what i do, i select the object and i point to the folder, where the textures are and 3dsmax render each frame with the texture. Put the cameraname, filename and texture name into the filepath. That works great so far.
The thing is now, i want to add the textures as Multi/Sub object, every texture has it´s own ID and add to the material the bump map. So every bump map has it´s own 30-40 textures. After this, i need the used bumpmap and the used texture and the name of the selected object as filename.
Graph
feel free to adapt this:
	local objsToSwitchTextures = selection as array;	--define the objects that will have their textures replaced
	local textureFolder = @"C:\Users\Graph\Desktop\Neuer Ordner (2)\";	--define the folder to search for the replacement-textures
	local fileType = @"*.jpg";	--define the fileType of the textures to use
	local mapSlotName = "DiffuseMap";	--define the material's map slot to assign the new textures to
	local printMapSlotNames = true;	--if set to true the material's map slot Names are gonna be printed to the listener
	fn getMatMapProps mat =
		if mat != undefined AND superClassOf mat == material do
			local str = stringstream ""
			showproperties mat to:str
			str = filterstring (str as string) "\r\n"
			local nonCollClasses = #(integer, float, array, arrayparameter, booleanclass, color, material)
			str = for prop in str where findString prop "alias" != undefined OR findString prop "map" != undefined collect
				local prop2 = 0
				prop = replace prop 1 (findString prop ".") ""  --remove whiteSpace before prop
				prop = substring prop 1 ((findString prop " ")-1) --cut out only the prop
				local firstLetter = toUpper (substring prop 1 1) --get first letter in uppercase
				prop = replace prop 1 1 firstLetter --replace first letter with uppercase
				if hasProperty mat prop do --check if the generated prop string exists at all
					prop2 = getProperty mat prop --get the value
				if findItem nonCollClasses (classOf prop2) == 0 AND findItem nonCollClasses (superClassOf prop2) == 0 AND prop.count > 6 then prop else dontcollect --sort out and return the valid props to collect
			return str
	)--END getMatMapProps FN
	local textureFiles = getFiles (textureFolder + fileType) ;
	local isRndNameSet = rendOutputFilename.count >=5;
	local rendFilename = copy rendOutputFilename;
	if objsToSwitchTextures.count > 0 then
		if textureFiles.count > 0 then
			for texture in textureFiles do
				for obj in objsToSwitchTextures do
					if obj.material != undefined do
						if printMapSlotNames do
							local matMapProps = getMatMapProps obj.material;
							local str = obj.material.name + " | " + (classOf obj.material) as string + "\r\n";
							for slot in matMapProps do
								str += "\t" + slot + "\r\n";
							print str;
						if isProperty obj.material mapSlotName then
							local tex = bitmaptex fileName:texture;
							setProperty obj.material mapSlotName tex;
							format "Cannot find mapSlotName \"%\" in material % : %\tPlease change the code in Line #9\r\n" mapSlotName obj.material.name obj.material
				if isRndNameSet then
					local fName = (getFilenamePath rendFilename) + (getFilenameFile rendFilename) + "_" + (getFilenameFile  texture) + (getFilenameType rendFilename);
					rendOutputFilename = fName;
					format "File % rendered\r\n" fName;
					local fName = textureFolder + ("batchMatReplace_" + (getFilenameFile  texture)  + ".png");
				render outputfile:rendOutputFilename;
			Messagebox "No Textures where found\r\nMake sure to propeprly define the TextureFolder AND FileType in lines #4 && #6";
		Messagebox "You didn't select any Objects to replace Textures on";
	rendOutputFilename = rendFilename;
