create dotnetcontrol buttons inside function
I want to create buttons depending on certain things!
So here is what I need:
fn myfunction=
for i=1 to IDcount do
     dotnetcontrol ID_btn[i] "System.Windows.Forms.Button" width:20 height:60 pos:[27,i*153]
     ID_btn[i].backcolor  = (dotnetcolor 70 70 70)
     ID_btn[i].flatstyle = dotnetobject "System.Windows.Forms.FlatStyle" Flat
     ID_btn[i].text="1"
     ID_btn[i].foreColor = (dotnetcolor 200 200 200)
How to make it work?
barigazy's picture
Then use simle "Panel"
Then use simle "Panel" control for the buttons (simpliest container)
dotnetcontrol pn "Panel" pos:[5,5] width:390 height:378
barigazy
artrender.info's picture
I just didn't understand
where did you define the width and the height for the panel1 and panel2?
I will add controls just for the visible textures in datagrid, that's why it will be not slow!!!
barigazy's picture
I not define them in this
I not define them in this example. But you can anywhere inside function, and if you need to be changed in some point then you need to add also arguments in fn definition like i did for width and height (w: and h:)
barigazy
now it's much interesting!
I'm implementing now to my code!!!!!
Thx barigazy, I think this will do what I want!
barigazy's picture
Believe me your trouble just started. :) Don't experiment too much with additional controls because your tool will become slower and slower.
barigazy
Oh, yeeeeeeeeeeeeeees!!!
now I have what to work with!
Is it possible to clear pn.controlls? so that they would be empty and to recreate in case my list updates!
barigazy's picture
.net clear method
-- to remove all buttons
sp1.panel2.controls.Clear()
-- and for panel probably
pn.controls.Clear()
barigazy
what is dock
in which cases it should be used?
how to add split containers iteratively?
how to fill every container with a button?
srry for all these questions, but if understand this then I know how to go on!
Thank you Barigazy, I would not be able to make it by myself!
barigazy's picture
Dock propert allow you to
Dock propert allow you to entirely fills the container with specified controls. Similar to align in max script. This option not work well in may last example I don't know why.
Explain better "Iteratively"?
Using for-loop collect buttons
try(destroyDialog testR)catch()
rollout testR "Test" width:400 height:400
	dotnetcontrol pn "MaxCustomControls.MaxUserControl" pos:[5,5] width:390 height:378
	fn defColor r g b = ((dotNetClass "System.Drawing.Color").FromArgb r g b)
	local COL1 = (defColor 80 80 80), COL2 = (defColor 150 150 150), COL3 = (defColor 65 125 88), COL4 = (defColor 125 150 80)
	local sp1 = dotnetobject "SplitContainer"
	local sp2 = dotnetobject "SplitContainer"
	fn defineSplitCont sp mainPnl clr1 clr2 w: h: dock: spliter:2 orient:#vert ctrlsIn1st:#() ctrlsIn2st:#()=
		sp.panel1.backColor = clr1
		sp.panel2.backColor = clr2
		sp.splitterWidth = spliter
		case orient of
			(#vert): sp.Orientation = sp.Orientation.Vertical
			(#horiz): sp.Orientation = sp.Orientation.Horizontal
		if dock then (sp.panel1.DockPadding.All = sp.panel2.DockPadding.All = 0 ; sp.dock = sp.dock.fill) else
			if w != unsupplied and h != unsupplied do (sp.width = w ; sp.height = h)
			sp.Location = dotNetObject "System.Drawing.Point" (mainPnl.pos.x) (mainPnl.pos.y)
		if ctrlsIn1st.count != 0 do sp.Panel1.controls.AddRange ctrlsIn1st
		if ctrlsIn2st.count != 0 do sp.Panel2.controls.AddRange ctrlsIn2st
		sp
	fn defBtn pnl txt: w:50 h:50 cnt:0 =
		btn = dotnetobject "Button"
		btn.text = txt
		btn.width = 50 ; btn.height = 20
		btn.Location = dotNetObject "System.Drawing.Point" 5 (-15 + (cnt*btn.height))
		btn
	on testR open do
		pn.backcolor = pn.backcolor.black
		pn.BorderStyle = pn.BorderStyle.FixedSingle
		pn.width = 390 ; pn.height = 390
		defineSplitCont sp2 pn COL3 COL4 dock:off spliter:2 orient:#horiz
		defineSplitCont sp1 pn COL1 COL2 w:378 h:378 dock:on spliter:2 ctrlsIn1st:#(sp2) ctrlsIn2st:(for i = 1 to 10 collect (defBtn sp1.panel2 txt:("Btn_"+i as string) w:50 h:10 cnt:i))
		pn.controls.add sp1
createDialog testR
barigazy
THX Barigazy
I will try it when I come back! Thank you thank you thank you!!!
