MAXScript not responding
By kimarotta · 2012-05-30
MAXScript often stops responding, anyone know why? how to solve? a similar problem?
thanks
Comments (11)
Escape works!
Vamshi Goud · 2014-09-09
presssing esc key works
kilad · 2012-05-30
this happens when you miss a paranthesis in the codeblock..
just evaluate ) and you're back in biz
indeed
jos · 2012-05-31
that's it! thanks a lot
jos · 2012-05-30
Sometimes I have the problem that the listener/maxscript doesn't work. It just doesn't respond anymore. Dont know why. When I restart max everything is back normal. Does anyone know how to reset the listener or something?
barigazy · 2012-05-30
Bad executed code :).
Just press ESCAPE key. Sometime this will unblock listener.
Listener will print
** interrupted **
jos · 2012-05-30
hmm possible, will try it next time!
I will also try the next time
tks
I mean *escape key* in listener.:)
Show your problem. Bad code is always a reason why this is happening.
so this problem usually occurs right after the run loop, but is not always the case. In MAXScript another computer stopped working no more answers ... Once I have this problem again I'll post here ...
Ok. But be careful when you use "while" loops.
Sometimes i have same problem.
