hello
I can't find how to uncheck "show vertices as dots" checkbox via maxscript...
Anybody ?
By titane357 · 2013-04-19
hello
Anybody ?
d1myan · 2018-04-24
sorry, working
harumscarum · 2013-04-22
by the way how to make toggle to turn on/off vertex as dots on selected objects?
miauu · 2013-04-22
I think that the preferences.useVertexDots(or using the Preferences Dialog) is global, so it is valid for all objects. But I am not sure about that.
Can you do it manually - to show vertices as dots for selected object?
harumscarum · 2013-04-23
yeah. just toggle for this checkbox in object properties
try this
barigazy · 2013-04-23
macroScript vertTicksToggle category:"vtToggle" buttonText:"vtToggle" tooltip:"Vertex TicksToggle"
fn filt obj = isKindOf obj GeometryClass or isKindOf obj shape
if selection.count != 0 do
for o in selection where filt o do o.vertexticks = not o.vertexticks
No work in 3dsmax 2018
d1myan · 2018-04-23
Very good script, which I used until today. But now it does not work in 3ds max in 2018. Help: how to fix it?
miauu · 2018-04-23
I have tested it in 3ds Max 2018 and it works with no problems.
miauu · 2013-04-22
I found it using "as dot" typed in the search field.:) Then I searched each topic for "as dot". Fortunately in this case it was in the first topic. :)
titane357 · 2013-04-22
yeees, found, but searching need to know exactly what and where to search...
miauu · 2013-04-19
It is in maxscript help file. Search for preferences.useVertexDots and you will find it.
preferences.useVertexDots =
miauu · 2013-04-19
preferences.useVertexDots = false -- true
thanks a lot :-)
question : where can I find this info ? I didn't find in maxscript help ?
