Update Button Text
By Michele Marcelli · 2009-12-20
Hello everyone!
In the example below, I have a button that opens the Material/Map Browser dialog and the text of the button takes the name of the texture map(fron Help MaxScript).
The button "Close" destroy the rollout. All ok.
Now, when I reopen the dialog, the mapbutton text is again "None". It is normal because the label of the button is "None" but, how to update a text of a button with the name of the texture map that I have chosen?
I created a script where added the Texture map of a light($.projectorMap), but every time I reopen the panel, the button no longer has the name of the map (see in Advanced Effect of the light).
rollout test "Test Txt"
button cr "Create Light"
mapbutton a "None" map:undefined
button b "Close"
on cr pressed do
lig=TargetDirectionallight pos:[200,0,0] isSelected:on target:(Targetobject transform:(matrix3 \ [1,0,0] [0,1,0] [0,0,1] [0,0,0]))
on a picked texmap do
lig.projectorMap = texmap
a.text=classof texmap as string
on b pressed do destroydialog test
createdialog test
Can someone help me?
Thanks in advance
Its important how you wish to store your object into the rollout (by name is an easy way) and to use "open" handle to backup what you need to the rollout.
	local lig -- important !
	button b "Close"
	on cr pressed do
		lig=TargetDirectionallight pos:[200,0,0] isSelected:on \
			target:(Targetobject transform:(matrix3 1)) \
				name:"Example" -- important !
	on b pressed do (destroyDialog test)
	on test open do -- important !
		lig = getNodeByName "Example"
		if isValidNode lig do
			if superClassOf lig == light do
				if lig.projectorMap != undefined do
					a.text = (classOf lig.projectorMap) as string
createDialog test
Reply to Panayot Karabakalov
Michele Marcelli
Anubis, I do not know how to thank you. I have to go around the world in 3 days? :) :)
Are days that I want a solution that I found. But you, open my mind! I thought everything except your solution.. still have a long way to go with MaxScript.
Thank you for your kind reply!
