Can u makes this script working with selecting 2 objects and changing the two objects textures at the same time 🙂 ...
thanks
http://www.scriptspot.com/forums/3ds-max/general-scripting/maxscript-to-batch-render-with-automatic-texture-changesForum topic · Scripts Wanted
By nithin · 2014-07-05
thanks
thanks miauu .... works fine ...
can u
change the 2nd texture / material property ( MONO CHANNEL OUTPUT To : Alpha Instead Of RGB Intensity ....
will pay / donate to you :)
Try this:
I've changed the file type of second object to PNG, because Alpha output works with file types that supports alpha. Change it as you need.
I don't have time to test the script.
How to use it:
- select first object and press the Get First Object buton. Then select the folder wherer are plaved the textures for the first object.
- select the second object and do the same as for the first
- Important - the count of the textures in both folders(for the first and the second objects) must be the same. For example 101 textures in folder01 and 101 textures in folder02
- Open Render Setup dialog(hotkey F10) and select the width and height of the rendered images, the output path, the base name for rendered images and so on.
-Press the RENDER button.
The script save rendered images in the folder, specified in the Render Setup Dialog.
