Change UI colour when snap / lock is active ?
Just a quick question to you guys, is it possible using Maxscript to change the colors of the UI when snap or lock is active ?
I'm simply looking for a way to give a better indication in the viewports that snap or lock is active.
For example changing the background colour to a different shade.
thanks.
for snaping you can use
And for selection lock this is the hack
(maxscript not provide better solution)
So it is possible ? Main
So it is possible ?
Main reason is I'm not always looking at the snap and lock buttons I'm looking in the viewport, I always forget they are on.
I'm looking for some way to indicate more clearly in the viewport that a toggle is active.
Ideally that would be background colour.
probably U will get flickering of the viewport if you do this.
I not know why you need that when lock and snap buttons are properly indicate lock or snap current state
