Script Speed
I have written a script which will do something like this:
Detach faces applied with material whose name ends with "_alpha" (material name) to new objects, and put those new objects inside a group called "Alpha_blending_mesh".
The script is running perfectly fine and doing exactly what I intend it to do. But the problem is it is running fast only the first time....from the next time it is taking too long (specially for complex scenes with too many objects).....again if I restart max it is running fast for the first time. I am not sure what is happening once I run the script for the first time....which is making it slow from the next attempt!! I have tried gc()....clearundobuffer()...nothing is working!! I have saved the files after I ran the script once....restarted max and ran it again...it again works fast for the first time....so the problem is not in the file...something is eating up the memory after the first run!!
I have written this by following this forum but since it is my first script it might look very clumpsy and funny :P.....here is the script:
undo off
-- delete previous groups named "Alpha_blending_mesh"
objgroup = #()
for o in helpers do
if o.name == "Alpha_blending_mesh" then
append objgroup o
if objgroup.count != 0 then
for i = 1 to objgroup.count do
ExplodeGroup $Alpha_blending_mesh
--will merge all vertices with threshold 0.001 if the obj is not inside a group
fn weldverts obj =
result = isGroupMember obj
if result == false do
$.weldThreshold = 0.001
polyop.weldVertsByThreshold obj #All
-- Collect objects from scene in working list
workingObject = #()
for o in Geometry do
if classof o != bonegeometry do
append workingObject o
fn Singlemat obj =
mat = obj.material
TextureFileName = "notexture"
if (classof obj != bonegeometry) and (mat != undefined) and classof mat.diffuseMap == Bitmaptexture do
stringSS = mat.name
stringcount = stringSS.count
if stringcount > 6 then
TextureName = substring stringSS (stringcount - 5) ((stringcount - 5) + 6)
if TextureName == "_alpha" do
objname = obj.name
stringTT = objname as string
stringTTcount = stringTT.count
if stringTTcount > 6 then
ObjnameTT = substring stringTT (stringTTcount - 5) ((stringTTcount - 5) + 6)
if ObjnameTT != "_alpha" do
obj.name = objname +"_alpha"
fn detachFBI obj =
objname = obj.name
ids = obj.material.materialIDList
for id in ids do
obj.selectbymaterial id
_faceSel = polyOp.getFaceSelection obj
polyOp.detachFaces obj _faceSel delete:true asNode:true name: (objname +"_tempdelface")
select $*_tempdelface*
$.name = objname
-- Run though all objects in array and detach them
for o in workingObject do
(mat = o.material
if (mat != undefined) and (classof mat == Multimaterial) do
select o
detachFBI o
delete o
--assigning single material to all object (removing unused multimaterials)
for o in geometry where isKindOf o.material multimaterial and (classof o != bonegeometry) do
-- Get face material ID from face 1
local id = getFaceMatID o.Mesh 1
-- Assign that material
o.material = o.material[id]
-- Run though all objects and check for "_alpha" in diffuse map, rename objets as *"_alpha"
for g in geometry do
select g
Singlemat g
--group as "Alpha_blending_mesh"
clearselection()
select $*_alpha
if $ != undefined do
group selection name:"Alpha_blending_mesh"
--attaching same named objects and welding vertices by 0.001 thresold
newworking = #()
for o in geometry do
if classof o == editable_poly and classof o != bonegeometry do
append newworking o
i = 1
while i <= newworking.count do
b = newworking[i]
j = i + 1
while j<= newworking.count do
if (newworking[j].name == b.name) then
b.attach (newworking[j]) b
deleteItem newworking j
select b
weldverts b
j = j +1
i = i + 1
--set final selection to group "Alpha_blending mesh, tool to 'move' mode, panel to 'modify' mode"
groupName = "Alpha_blending_mesh"
grp = getNodeByName groupName
if isValidNode grp and isGroupHead grp do
select $Alpha_blending_mesh
toolmode.commandmode = #move
setCommandPanelTaskMode mode:#modify
kimarotta.com.br
3d Artist
:) :). Yea Instead of using
:) :). Yea
Instead of using "code" you can use also "mxs"
please put your code betwen
<code>kimarotta.com.br
3d Artist
Sorry its not working....what
Sorry its not working....what am I doing wrong??
