Toggle xRef Scenes / xRef Objects
Hello all,
So of course i'm aware that you can just get to the xRef Scenes / xRef Objects by going through File -> Reference.
But i like to toggle the xRef Scenese / xRef Objects by using a script. I have my own "summary script" in which i like to include them.
So i'm looking for the function to toggle these two, unfortunately i couldn't find these online. Hopefully you can help me :)
Thank you.
I am glad to help.
Happy New Year!!! :)
Also, i’m noticing that you use an @ in your FileIn function while i am not. Might that make a difference?
There si two ways to use path to folder/files with maxscript:
Since, copyed path from the Windows explorer not contains "\\" it is easyer to put @ in front of the path and not add \ where it is needed.
I’ll try it out when i’m at work again in a few days. Besides the fact that you make a macroscript of it, put the function between brackets and that you make a button out of it. It seems all the same. The function is loaded from a file over a network drive but i wouldn’t see why that would be a problem here.
I’m sorry that is my fault. I
I’m sorry that is my fault. I explained it a bit confusing because i wrote Toggle. What I like to just open the xRef Scenes / xRef Objects through maxscript.
Thanks miauu
For xRef scene:
Thanks miauu
