Distance Align Then Distribute
I would like a script that does two things with the option of doing both or each individually.
It is just like the Distribute tools for layers in Photoshop.
Example: You have a scene with a handful of objects that you want to distribute.
http://www.scriptspot.com/files/distance.png
Option 1: The script takes the selected objects and without moving/adjusting the end objects (which would be the two objects furthest from each other) the script would align them all. Think of it as if you made a straight line between the 2 end objects and then moved each object in between to match that line.
http://www.scriptspot.com/files/distancealign.png
Option 2: Would take all the objects except for the 2 end objects and then evenly distribute those objects along the virtual line that would be drawn between the 2 end objects. Which would result in all the objects being evenly space apart based on there pivot or bounding box.
http://www.scriptspot.com/files/distancedistribute.png
JokerMartini
distance.png40.81 KB
distancealign.png40.78 KB
distancedistribute.png39.9 KB
Swordslayer's picture
One way to get the objects
One way to get the objects furthest away from each other is to use parts of the previous scripts (you can merge them later, I don't have much time right now so I leave that part to you), like:
fn getFurthestNodes objs =
	struct geom_item (obj1, obj2, dist)
	fn compareDist obj1 obj2 =
		obj1.dist - obj2.dist
	local already_checked = #()
	distances_arr = for o in objs collect
			local item_arr = for item in objs
				where findItem already_checked item == 0 AND item != o collect
					geom_item obj1:o obj2:item dist:(distance o.pos item.pos)
			with redraw off
				qsort item_arr compareDist
			append already_checked o
			if item_arr.count == 0 then continue else item_arr[item_arr.count]
	with redraw off qsort distances_arr compareDist
	local result = if distances_arr.count != 0 do
		distances_arr[distances_arr.count]
	if result != undefined do
		select #(result.obj1,result.obj2)
Again, to use it just evaluate it and then you can pass it whatever you like, e.g. getFurthestNodes selection It selects the resulting nodes for you this time ;)
JokerMartini's picture
This is what I was looking for.
you'll have to make two objects as your start and end and the run the script on the selected objects. It is not a streamline thing just yet but I wanted to show you what i wrote as where i was going with this.
Make sure your start object is at 0,0,0
	local EndObj = $end
	local StartObj = $start
	local userSel = $Sphere003
	local averageVal = [0,0,0]
	local userSel = selection as array
	fn averagePos startVal endVal =
		userSel = getCurrentSelection()
		averageVal += (startVal.position + endVal.position) ; averageVal /= (userSel.count+1)
	if userSel.count > 0 do
		Val = averagePos StartObj EndObj
		   Obj = selection[i]
			print Val
		   Obj.position = [(Val.x*i),(Val.y*i),(Val.z*i)]
	  completeRedraw()
John Martini
Digital Artist
This is exactly the same as
This is exactly the same as the alignAndDistribute2 function if passed the type:#evenly argument with the exception that here you have to specify one object extra (and have one object at [0,0,0] coordinates) and as you don't sort the objects, they're aligned not based on their positions but rather their positions in the selection array (i.e. you get random results depending on the way you select them. As for finding out both the "border" nodes, in some sitations it could work, but those would be quite special. You have to pick at least one object as the starting one - that's what I did. I'm not sure if you tried the function, be sure to do it and then we can discuss what you think is missing/not working as you imagined.
Here you go:
Here you go:
fn alignAndDistribute obj_arr distr_line type:#closest =
	obj_nr = obj_arr.count
	case type of
		#closest:
			fn pointLineProj pA pB pC =
				local vAB = pB - pA
				local vAC = pC - pA
				local d = dot (normalize vAB) (normalize vAC)
				(pA + (vAB * (d * (length vAC/length vAB))))
			for objs in obj_arr do
				new_pos = (pointLineProj (getKnotPoint distr_line 1 1) (getKnotPoint distr_line 1 2) objs.pos)
				objs.pos = new_pos
		#evenly:
			local start_pos = getKnotPoint distr_line 1 1
			local point_dist = (getKnotPoint distr_line 1 2 - getKnotPoint distr_line 1 1)/(obj_nr + 1)
			struct geom_item (obj, dist)
			dist_arr = for g in obj_arr collect geom_item obj:g dist:(distance g.pos start_pos)
			with redraw off
       			qsort dist_arr compareDist
			for objs in dist_arr do
				start_pos += point_dist
				objs.obj.pos = start_pos
Pass it some objects, a line (to keep it simple, it has to have 2 knots and 1 spline to work as expected) and distribution type. When object will be "out of the range" of the line (i.e. somewhere else than the other objects), the sorting may give unexpected results, but for the situation on your pictures, it will work. PointLineProj function implementation comes from prettyPixel.
Example usage: alignAndDistribute (selection as array) my_line type:#evenly
Well, looking at it again,
Well, looking at it again, looks like I should learn to read first :) Anyway, if you want to use it for object collection without a line, use this version instead:
fn alignAndDistribute2 obj_arr start_node type:#closest =
	local start_pos = start_node.pos, end_pos, point_dist
	with redraw off
	end_pos = dist_arr[dist_arr.count].obj.pos
	point_dist = (end_pos - start_pos)/obj_nr
	deleteItem dist_arr dist_arr.count
	case type of
		#closest:
				local vAB = pB - pA
				local vAC = pC - pA
				new_pos = (pointLineProj start_pos end_pos objs.obj.pos)
				objs.obj.pos = new_pos
		#evenly:
Pass it some border object (it's hard to find one programatically in many situations when some coordinates you'd like to test against are the same and so on) and the rest of the objects to be aligned. Now it should be roughly what you wanted in the beginning.
