Edge Constraint Toggle
Hi guys!
So, I started to make a script that basically shows me on the UI if the edge constraint it ON or OFF on the selected object.
Basically I have it as a button on the UI, and when I have an object selected and I press the button It toggles it and enables Edge constraint to edge and stays lit up. But when I deselect the object the toggle is still on.
Would it be possible for the Toogle button to make the test on the object i select and see if the edge constraint is on and toggle it acordingly.
Obviously if its a group of object it wouldnt do anything, i think.
This is what i have.
macroScript test category:"Tests" ( local isOn = false --initialize to false (closed) on execute do ( if ( $ != undefined) then ( if isOn == true then ( --if open, close it isOn = false--and lower the flag $.constrainType = 0 ) else ( --if closed, open it $.constrainType = 1 isOn = true --and raise the flag ) ) ) on isChecked return isOn --return the flag )
i have both the script as a button and a shortcut, so basically it runs the script on the object and togles the button on or off.
Cheers!
-P
This
will print in the listener the current active Cosntraynt type.
So when you press the button/hotkey you can check the active constraint type and can change it or not.
