Why we so complicated... yeah, SetVert function missed in the help for epoly_mod but it work :) so if i say: ep.SetVert #{8}[10,20,30] then my vert 8 is set to that [10,20,30] pos in a world space. So next code is fine for me:
max modify mode
!REG3XP1!>modPanel.setCurrentObject ep
verts = ep.GetSelection #Vertex
ep.SetVert verts [10,20,30]
(* remove "!REG3XP1!>", i seen this before, its not a part of the code but forum addition)
Yep, the lack of functions in epoly mod complicate it usage. For example, if I move vert with MoveSelection() and need the new vert coords, I s'd add TurnToMesh mod, else get the old vert pos, realy odd. Not sure is it a bug in my Max (2009) or general limitation but its weird :(
It was a while back when I used epoly mod for a last time :) Maybe s'd check SetSelection() function. Not sure, but it may not refresh correct. Try to cleanup 'old' selection and then set new one, i.e.:
ep.SetSelection #Vertex #{}-- clear sel.
ep.SetSelection #Vertex #{vert}-- then set new
Also about the MoveSelection() ... needs a bit of measurement here...
trgPos = [10,20,30]for vert in selVertArr do(
ep.SetSelection #Vertex #{vert}-- measure new coords
curPos = ep.GetVertex vert
movePos = curPos + (distance trgPos curPos)if curPos.x > trgPos.x do movePos.x += -1
if curPos.y > trgPos.y do movePos.y += -1
if curPos.z > trgPos.z do movePos.z += -1-- then use 'move'
ep.MoveSelection movePos
Hmm, yep, I not see setVert() for epoly modifier :/ If polyop.setVert not works, then try again with MoveSelection but iterate and because its affect selected then just select only 1 vert in the loop, that s'd do the trick, I think.
ep = selection[1].modifiers[#Edit_Poly]
modPanel.setCurrentObject epmod
SetEPolySelLevel #Vertex
subObjectLevel = 1
selVertArr = ep.GetSelection #Vertex
ep.MoveSelection [10,20,30])
Hi John,
am not sure i catch your goal.. 'move' is an offset function, moving vert with world coords [10,10,10] with [20,20,20] will put it in a [30,30,30], its exact as PosPoint3 += PosPoint3. Maybe you try to set all selected verts to the 'constant' point in space? If so, try polyop.setVert.
How do I move the selected vert to a specific location in world space, not local. Which is moves in local right now.
I want to be able to type in a point 3 value and move the selected vert to that position.
selVertArr = selection[1].modifiers[#Edit_Poly].getSelection #Vertex
for vert in selVertArr do(selection[1].modifiers[#Edit_Poly].moveselection [10,10,10]
Nice work
That's great. It does work.
This is what I've got as the final resulting code.
Next is figuring out how to set just one axis such as only the X
John Martini
Digital Artist
Hey, SetVert work for me! :)
ep.SetVert #{8} [10,20,30]then my vert 8 is set to that [10,20,30] pos in a world space. So next code is fine for me:max modify mode !REG3XP1!>modPanel.setCurrentObject ep verts = ep.GetSelection #Vertex ep.SetVert verts [10,20,30](* remove "!REG3XP1!>", i seen this before, its not a part of the code but forum addition)
Let me know if this help.
Yeah it's still seeming to
Yeah it's still seeming to not working right.
I feel like this task should be simpler than it is haha.
It's not moving the selected verts.
John Martini
Digital Artist
if not setVert then try (SetSelection + MoveSelection)
Yeah it doesn't seem to be working.
This is what i've come up with that is bugging out.
This is for the edit poly modifier don't forget.
John Martini
Digital Artist
I simply just want to set the
I simply just want to set the world position of a selected vert.
For example a i want to select a vert and then move it to [10,20,30] in world space.
John Martini
Digital Artist
Hi John,
polyop.setVert.my recent MAXScripts RSS (archive here)
John Martini
Digital Artist
Use this to get the point3
Use this to get the point3 coordinates:
-- 102 is the index of the esired vertex
$.modifiers[#Edit_Poly].GetVertex 102
vArr = $.modifiers[#Edit_Poly].getSelection #Vertex
for v in vArr do print ($.modifiers[#Edit_Poly].GetVertex v)
