instances to separate layers
Guys here's the script idea:
I need a script that would move all the instances (of multiple definitions) from the current selection to the separate layers
For example in the current selection I have 10 instances called AAA_ , 10 instances called BBB_ , 10 instances called CCC_ etc..
The script would create the separate layers in accordance to instances names, but starting with prefix z_ :
z_AAA
z_BBB
z_CCC
and move the instances to related layers (all AAA_ instances will be moved to layer z_AAA, BBBs to layer z_BBB etc)
P.S. Instances have numbers in its names, typically AAA_001, AAA_002 etc - the script should ignore them
P.P.S. Ideally I'd like the this script to continue and create dedicated Forest Sets based on those new layers, but maybe I'm asking too much :)
The script is needed for creating reference forests based CAD blocks coming from Sketchup, Autocad, etc..
Thank you
This will launch this script
This will launch this script to stratosphere:
Is it possible to add an optional button "add FP geo"?
(I'd create FP in the rRef mode with selected entities) :)
P.S. I PMed you (@free.fr)
updated script
https://www.mediafire.com/file/y9izl2rf83sgzqb/Instances_to_layers_For_F...
Previous version has a bug when forest pro version was used.
there is still a limitation to this script, every sets of instances need to have a different base name or the script crashes because layers are created based on those instances names stripped of the "_00x"part.
for example: Object_001,Object_002,Object_003,etc... and Other-Object_001,Other-Object_002,Other-Object_003,etc...
Hi miauu,Good idea for the
Hi miauu,
Good idea for the (trimRight o.name str0123456789_), its better then my (substring obj.name 1 (obj.name.count - 4), also your function for collecting unique nodes looks better,and the check for already existing layer with the same name is also a good idea.;)
But there is something that doesn't work well in your script, if you have objects in selection that are referenced copys it will create a layer for them aswell, that is why i added this line: trueInstances = for n in instances where (areNodesInstances obj n) collect n
also i noticed that your script was creating a layer for objects that aren't instanced if selection contain non instanced object.
i've updated my earlier post to add the forestset creation, now that i see your post, maybe we should merge the two versions...:)
By the way thanks for all your post, you have been really helpfull, i am new to scripting and i've been learning a lot from you.
Also, i was wondering how to post code in a "window" like you, mine has been all messed up when i posted it (every line start at the begining of a line).
edit:
Here is a merged version of both script:
local imGetInstances = InstanceMgr.GetInstances
fn collectUniqueNodes nodes: =
local handles = #{}
for o in nodes where not handles[GetHandleByAnim o] collect
imGetInstances o &inst
for i in inst do handles[GetHandleByAnim i] = true
o
local uniquenodes = collectUniqueNodes nodes:selection as array
for obj in uniquenodes do
imGetInstances obj &instances
if trueInstances.count > 1 do
local layername = "Z_"+(trimRight obj.name "0123456789_")
if (objLayer = layerManager.newLayerFromName layerName) != undefined then objLayer.addNodes trueInstances
else (layerManager.getLayerFromName layerName).addNodes trueInstances
if isForestPack != undefined do ForestSet pos:obj.pos layerimport:on layernames:layername
Hi, Simon!
I don't know if my code will work properly or not, because I don't have a scene to test with.
If you want you can scalp what you need from my code.
To properly post your code in the forum use this(without the quotes):
["code"]
-- your code here
["/code"]
Hi
thx Miauu,
For some reason i can't edit the earlier message but i can edit this one, so here is the updated code :
