script to ui installer
hello!
i have so many useful scripts by now, but no way of accesing them instantaneously,
is there an easy way to access my scripts on startup of max through the customize UI section, i know macroscripts can do this, but theres many scripts i have that arent macroscript, i just want to add them to my toolbar?!
any help would be greatly appreciated!
hi anubis, i have tried the
hi anubis,
i have tried the script but it deosnt save a file for me ?
please help
// www.v-motion.co //
jes if undefined nothing
jes if undefined nothing happens, but of course i write a name, and at least it does save the test file! but with nothing in it,
does it matter where the macrocomposer.ms is sitting, lets say on the desktop or in scripts folder?
if outputName != undefined
if outputName != undefined then
is used to check is save dialog confirmed or canceled, so if you cancel no file saved. but why for you save empty file?... that's strange.
i also try it on computer
i also try it on computer here in office, doesnt work :(
i have a question
does it only create macro if output name undefined?
because it asks to save maxscript you have to enter name, which means, you define it ? so thats why the macro is empty?
i have tried putting the script even in scripts folder but doesnt change,
i get a macro file, but it is empty...
((getDir
((getDir #maxroot)+"\\scripts") = (getDir #scripts) ie they are return the same path. I'm to using max2009 x64 and realy have no idea why the script dont work for you ?!
str += "filein \"" +
str += "filein \"" + files[f] + "\"\n" + ")\n" + ")\n"
isthis the problem is it whee the maxroot is missing?
MacroScript new01
MacroScript new01 category:"phizikl" tooltip:"Animate It" buttonText:"at"
setCommandPanelTaskMode #create
on execute do
filein ((getDir #maxroot)+"\\scripts\\phiZikl\\Animation_Timer_v1.8.ms")
***this code creates a file for me,***
files = getFiles ((getDir #maxroot)+"\\scripts\\test\\*.ms")
if files.count != 0 then
for f = 1 to files.count do
templist[f] = getFilenameFile files[f]
for f in files do fname = FilenameFromPath f
outputName = getSaveFileName caption:"Save MaxScript File" \
types:"Script Files (*.mcr)|*.mcr|All Files (*.*)|*.*|"
outputFile = CreateFile outputName
str = "macroScript new" + (f as string) + " "
str += "category:\"test\" tooltip:\"aa"
str += templist[f] + "\" buttonText:\"" + templist[f] + "\"\n"
str += "(\n" + "setCommandPanelTaskMode #create\n"
str += "on execute do\n" + "(\n"
format "%" str to:outputFile
close outputFile
edit outputName
this code doesnt,
thats so weird (tried with maxroot as well, im using max2009 64bit
strange :) i know your code
strange :)
i know your code works something with directory problem
my directory is
C:\Program Files\Autodesk\3ds Max 2009\Scripts\test
( i also try it with phiZikl folder which has 20scripts, and my "manual" code works for that)
macroScript new01 category:"phizikl" tooltip:"Animate It" buttonText:"at"
on execute do
maybe thats the problem?
MAXROOT is missing?
ijes i changed the last line
ijes i changed the last line now,
now it creates a macro file!
only it is empty :)
under Scripts/test/ i have two files now test.ms and rest.ms just for example,
it produces file but no code inside,
weird
There is the file attached
