hello
I look for a script to select just one instance of an object :
- select all objects I want to work with
- run the script
- just one instance of each object is selected.
if selection.count != 0 do
local firstInstances = #()
for o in selection do
InstanceMgr.GetInstances o &firstOnly
if firstOnly.count > 1 do
append firstInstances firstOnly[firstOnly.count-1]
if firstInstances.count != 0 do select firstInstances
fn collectUniqueNodes objs = if objs.count != 0 do(
local getNodeByHandle = maxOps.getNodeByHandle, getObjIns = InstanceMgr.GetInstances
local uniqNodes = #(), allINodes = #()for o in objs do append allINodes o.inode.handle
while allINodes.count != 0 do(
obj = (getNodeByHandle allINodes[allINodes.count])if isValidNode obj do append uniqNodes obj
if not (refhierarchy.IsRefTargetInstanced obj) then deleteItem allINodes allINodes.count else(
getObjIns obj &firstOnly
for o in firstOnly where (idx = findItem allINodes o.inode.handle)!= 0 do deleteItem allINodes idx
uniqNodes
Now "objs" argument in fn represent array ei.collections of object.
If you want to consider only selected objects then run
collectUniqueNodes selection
to consider only geo-objects use
arr = for o in geometry where not isKindOf o TargetObject collect o
collectUniqueNodes arr
Still now working for me...
We are putting a script together to clean up imported CAD geometry. What we would like it to do is to selects all non instanced objects and a single instance of the instanced objects.
our goal is to select only the necessary objects prior to running the other scripts such as delete isolated verts, weld and smooth, flip inverted normal, quadrify ect...
Using this fn U can do what you want
collectUniqueNodes selectionto consider only geo-objects use
I would appreciate any help.
Thank you!
I simplified fn and now it works fine
This works!...1000 Thanks!
Thanks!
Thanks!
Thank you very much ! :-)
