bitmap switcher
Another script...another newbie problem!
I'm trying to develop a script that let me change diffuse texture of a certain material.
I started studying Joe Gunn old script "face switcher": this script change material ID (but first we need to create a multiamterial with a lot of submaterials with different textures), while I think it's faster to have only one material and change its texture.
The script let you choose a directory to sort bitmap from, create thumbnails and...nothing.
The scope is to change material texture clicking on the corresponding thumbnail and to create a keyframe for material diffuse slot.
This is my result:
try(destroyDialog ::texchange)catch() rollout texchange"TEXTURE CHANGE" ( --interface button btnSetD "Set Dir:" pos:[5,5] width:50 height:20 toolTip:"directory immagini" edittext Fdir "" pos:[55,5] width:100 height:20 button btn01 "01" pos:[5,30] width:30 height:30 button btn02 "02" offset:[-30,-35] width:30 height:30 button btn03 "03" offset:[0,-35] width:30 height:30 button btn04 "04" offset:[30,-35] width:30 height:30 button btn05 "05" offset:[60,-35] width:30 height:30 --choose bitmap path on btnSetD pressed do ( local curpath = Fdir.text local newPath = getSavePath initialDir:(curpath) caption:"Select the path where your Face Images are located" if newPath != undefined then --create thumbnails ( Fdir.text = newpath btn01.images = #(Fdir.text + "\01.png", Fdir.text + "\01.png", 1, 1, 1, 1, 1) btn02.images = #(Fdir.text + "\02.png", Fdir.text + "\02.png", 1, 1, 1, 1, 1) btn03.images = #(Fdir.text + "\03.png", Fdir.text + "\03.png", 1, 1, 1, 1, 1) btn04.images = #(Fdir.text + "\04.png", Fdir.text + "\04.png", 1, 1, 1, 1, 1) btn05.images = #(Fdir.text + "\05.png", Fdir.text + "\05.png", 1, 1, 1, 1, 1) ) ) --actions on btn01 pressed do ( --and here the problem... load 1st thumbnail image to object material ) on btn02 pressed do ( --same, and so on... ) ) createdialog texchange 160 200 10 110 style:#(#style_titlebar, #style_sysmenu, #style_toolwindow)
I hope to have been clear enought... any idea?
Try this
Almost right, with your code the 1st keyframe is stepped, while the others are not.
With
works well!
Yep.
In this example I used first object in selection, first material in array and
of course first key
One problem solved, another discovered (::disappointed::)
As a dialog works fine.
Converted into a scripted plugin works too.
But I will have more than one character in my scene and I prefer to use this tool as a modifier: if I apply it to two objects with 2 different material it works, but button thumbnails are the same even if I pick 2 different directories (with different images).
Is a local variable (path) problem?
Path names in EditText disappered also...
Now I fix it with:
they are also saved with scene and restored on open....
but no way to fix thumbnails problem :(
Any idea?
By using below method you can avoid any error.
I hope that you understand what i wrote.
If not then just read mxs help.
If I wrote:
it works, but obviously is not what I need... it should be something like this:
but my knowledge stops here...
YEP!
I find a solution... is it the right one?
Better use "selection[1]" then "$" sign ei
You rock!
Thanks, I'm learning a lot from you in these days.
It works fine with a vraymaterial, but does not work (nor mine do) if vraymtl is a submat of a multimaterial...
