I get Map instead of Diffuse(I have there collor corect then texture in diffuse)
I want DIFFUSE/COLOR CORRECT/
Except this, I want all this info without the word
local bitmaps = getClassInstances BitmapTexture
fn capitalizeFirst str =
str[1] = toUpper str[1]
str
fn getTopMats sub =
for item in refs.dependents sub
where isKindOf item Material collect item
fn recurseMats mats map previous:#() =
for mat in mats dofor i = 1 to (getNumSubTexmaps mat)
where getSubTexmap mat i == map do(
local topMats = getTopMats mat
if topMats.count > 0 then
recurseMats topMats mat previous:(join #(capitalizeFirst ((classOf mat) as string) + "/" + getSubTexmapSlotName mat i) previous)else(format"\tSlot name: %"(substituteString (getSubTexmapSlotName mat i)" map""")for each in previous doformat"/%" each
format"\n"))for bmp in bitmaps do(
local mats = getTopMats bmp
format"\nTexture: %\n" bmp.name
recurseMats mats bmp
local mats = for item in refs.dependents bmp where isKindOf item Material collect item
where getSubTexmap mat i == bmp doformat"\tSlot name: %\n"(getSubTexmapSlotName mat i)))
SubTexmap methods work both for materials and maps, yet it is quite likely that some info will be missing - anything that will be missing in getClassInstances/refs.dependents calls.
THANK YOUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUU!
IT's working very well, the only thing is that when I use it I get
Slot name: Map 1
Slot name: Mask
Slot name: Radius
Slot name: Occluded
Slot name: Diffuse map
Slot name: Bump map
Slot name: Refl. gloss.
Slot name: Reflect map
Slot name: Bump map
Slot name: Bump map
Slot name: Bump map
map
for example - not BUMP MAP but BUMP.
In this case
Slot name: Map 1
Slot name: Mask
Slot name: Radius
Slot name: Occluded
Slot name: Map 2
Map1 and Map2 are located in Diffuse Slot/Fallof then - Map1 and Map2!
I would like to list tem like:
Difuse/Fallof/Map1
Difuse/Fallof/Map2
Thank you in advance!
( local bitmaps =
Some of my scripts and MCGs :: 3ds Max SDK Intro for Scripters
This will work in some
This will work in some cases:
