Help with the trimleft/trimright function
I've taken my favourite script and tried to learn from it. It's probably is a bit complicated for a beginner but I really wanted to add a function to trim any leading and trailing whitespace characters and also add an option for Title case and Sentence case. I read the manual and all I can see is:
ToLower + ToUpper
Is there another way to achieve Title case and Sentence case?
Any code that I've modified has --------------#### 3dwannab code ###-------------- beside it.
The area that needs attention is:
( if trailing_leading = false then
for i in selection do i.name = trimleft trailing_leading
I'm completely suck at the minute and I wanted to chat with someone on here to help me figure out what I need to do. I've managed to get the presets working as they should. It's just the function that needs a look at.
Not have time to look over the whole code.
Post me a snippet to see what is the problem.
Like this
let say i have en string *str*
Not quite understand what do you want to achive.
Just show me string before and after (result that you want)
Thank you so much.
Your information really helped me a lot!
