I want to change the messageBox behaviour in my script
Hello,
I have a script that looks like this:
macroScript AutoBackToggle category:"Haider" buttonText:"AB-Toggle" toolTip:"AutoBackup Toggle" ( on isChecked do (autoBackup.enabled) on execute do if autoBackup.enabled == true then ( autoBackup.enabled = false /*print (autoBackup.enabled)*/ messageBox "Autobackup disabled." title:"Autobackup State" beep:false ) else ( autoBackup.enabled = true /*print (autoBackup.enabled)*/ messageBox "Autobackup enabled." title:"Autobackup State" beep:false ) )
The messageBox command will lock the user, forcing one to press OK before continuing.
How do I change the popup to be a regular information popup that doesn't "lock" the viewport?
Replace it with regular rollout.
