Select Face Array
I need a help in faces...
I'm trying to collect some faces, some faces have an array but I can not load the array in setSelection ...
Thanks in advanced
prov = $.selectedFaces as integer -- Unable to convert: #faces(181, 234, 347 : $Editable_Poly:Plane003 @ [32.705963,272.583252,0.000000]) to type: Integer prov #faces(181, 234, 347 : $Editable_Poly:Plane003 @ [32.705963,272.583252,0.000000]) $.EditablePoly.SetSelection #Face #{prov} -- Unable to convert: #faces(181, 234, 347 : $Editable_Poly:Plane003 @ [32.705963,272.583252,0.000000]) to type: Integer
First if you use array and
First if you use array and you want to know the count then use:
But for bitarray you need to use:
very good and very thanks
very good and very thanks Barigazy...
and the question of vol. select has any idea?
kimarotta.com.br
3d Artist
Next time say if you use
Next time say if you use modifiers or not :)
For the editpoly mod you can use various methods
Read mxs help, topic Edit_Poly : Modifier
Sorry... and thanks again.
kimarotta.com.br
3d Artist
Are you preparing some new
Are you preparing some new script or just playing with modifiers?
Share at least one screenshoot :)
Hey... I am trying to solve a problem ... I'll try to explain ... I have a plane with a modifier "Vol.Select", and would like to collect the faces that "Vol.Select" select ... I select only the latest faces and not all. would like to create an ID for each selection group that creates the Box Plane ... you get the idea? I'm sending the file to the test ...
was trying something like...
p.s. I'm a begginer... help are welcome
kimarotta.com.br
3d Artist
lol.
I will try ...
very thanks
kimarotta.com.br
3d Artist
PolyOp Method
This is the same [PolyOp Method]
Swordslayer is faster
Swordslayer is faster :)
Cheers!
You can't convert as integer
You can't convert as integer but you can convert as bitarray
