Ultra-slow script exit...
I've got a fairly basic script (I can throw it here on demand) - I gather all of the materials in the scene with a specific prefix, confirm their sub-maps are of a specific type (via classof) - and then edit simple flags (visible, etc) - for them.
I added timestamping, and the code itself runs _fast_ - we're only talking a dozen or so simple materials. However right before it ends, it takes 30+ seconds to clear the final function. If I do _all_ of the code _except_ editing a map (I just comment out only the X=Y code) - it runs super fast, exits right away.
Does this raise a flag with anyone? Is there some specific dumb thing I may need to look for? I feel like the fact that the delay is only when an object is changed, that it's related to instancing or some sort of dirty-data cache... but the scene in terms of materials is not that complex - and 30 seconds is a _ton_ of time for a modern machine to do work...
Any and all thoughts would be appreciated...
fn matGather &mat &mats = ( if ((findstring mat.name "MAT[") == 1) then ( appendIfUnique mats mat ) mats ) fn matGatherMul &mat &mats = ( for m in mat.materialList do ( if (classof m == Standardmaterial) then ( matGather &m &mats ) ) ) fn matGatherScene &mats = ( for m in sceneMaterials do ( if (classof m == Multimaterial) then ( matGatherMul &m &mats ) if (classof m == Standardmaterial) then ( matGather &m &mats ) ) ) fn diffGetMap diff = ( if (classof diff == Bitmaptexture) then ( diff ) else ( if (classof diff == CompositeTexturemap) then ( diffGetMap diff.mapList[1] ) else ( undefined ) ) ) fn colorApply &cc apply = ( cc.lightnessMode = 1 cc.enableR = true cc.gainR = (apply.r/255)*100 cc.enableG = true cc.gainG = (apply.g/255)*100 cc.enableB = true cc.gainB = (apply.b/255)*100 ) fn teamCreate &diffM teamC stripeC = ( wantTeam = substitutestring diffM.filename "_DIFF." "_TEAM." wantStripe = substitutestring diffM.filename "_DIFF." "_STRP." teamM = undefined stripeM = undefined valid = 1 try ( teamM = BitmapTexture filename:wantTeam ) catch ( valid = 0 ) try ( stripeM = BitmapTexture filename:wantStripe ) catch ( valid = 0 ) if (valid == 1) then ( holdC = CompositeTexturemap() holdC.mapEnabled.count = 3 teamCor = ColorCorrection() colorApply teamCor teamC teamCor.map = teamM stripeCor = ColorCorrection() colorApply stripeCor stripeC stripeCor.map = stripeM holdC.mapList = #(diffM, teamCor, stripeCor) holdC.layerName = #("diff", "team", "stripe") holdC ) else ( diffM ) ) fn teamShow &mat show teamC stripeC = ( diffC = mat.diffuseMap diffM = diffGetMap diffC if (diffM != undefined) then ( if (classof diffC == BitmapTexture) then ( diffC = teamCreate diffC teamC stripeC mat.diffuseMap = diffC ) ) if (classof diffC == CompositeTexturemap) then ( if (diffC.mapList.count == 3) then ( if (diffC.layerName[2] == "team") then ( if (diffC.layerName[3] == "stripe") then ( diffC.mapEnabled[2] = show diffC.mapEnabled[3] = show if (classof diffC.mapList[2] == ColorCorrection) then ( colorApply diffC.mapList[2] teamC ) if (classof diffC.mapList[3] == ColorCorrection) then ( colorApply diffC.mapList[3] stripeC ) ) ) ) ) ) fn visualizeTeams show teamC stripeC = ( matSet = #() matGatherScene matSet for m in matSet do ( teamShow m show teamC stripeC ) -- DELAYS RIGHT HERE FOR AGES!!! matSet = #() )
I adde one more fn as filter
And the last one
BTW if your material name starts with MAT... then use pattern in this form "MAT[*"
I hope that this correction until now works faster.
Cheers!
Your code is too long. I'm sure that this can be shorter and better is you explain
what do you want to achive in brief
