when changes do
By zambi · 2016-06-28
I'm interested only construction "when changes do". File contains the code base, and three of the end.The first part of the code works well. When I add loop problems begin.(2-3part)
2 part - he does not see the value(i in loop) as local but he see the value as global (3 part)
3 part - performed only cycle end code
"when changes do"- expression works in the cycle? (Give an example of code)
In the code (2-3 part), value can leave a local variable?
pixamoon
Try this one:
str = stringStream ""
for i = 1 to 2 do (
	format "when transform Ar_Hpoint[%] changes do (setKnotPoint Ar_Line[%] 1 1 Ar_Hpoint[%].pos ; updateShape Ar_Line[%])\n" i i i i to:str
	format "when transform Ar_Hpoint[%+1] changes do (setKnotPoint Ar_Line[%] 1 2 Ar_Hpoint[%+1].pos ; updateShape Ar_Line[%])\n" i i i i to:str
execute(str as string)
Full code in attachemnts
Best,
Pixamoon
