Condense Same Named Materials to Master Instance Material
If I'm missing this, I'm sorry. But My scenes have multiple objects using the same materials with the same names, but they each come into the MatEd as individual materials. This is a huge PITA when I need to change one material then propagate that change across multiple objects.
Can someone write a script that finds all materials with the same name, have the option to correlate the materials to ensure they are actually the same setup (or with in a few parameter close) then use a master material as the new instance material that replaces all other same-named materials.
Please contact me with your costs and time availability. This is a need-it-now item.
Thanks in advance,
Curtis Sponsler | AniMill
OK, I have one suggestion:
OK, I have one suggestion: Have a "Select First" button where it automatically selects the first check-box in each multi-copy material. Just a short-cut to speed things along.
Thanks again.
cas
Bowing down low before
Bowing down low before you... you ever need some After Effects composites or MAX production, don't hesitate to email me: c.a.sponsler[at]animill.com
Thanks!
Haha, yeah I tend to make a
Haha, yeah I tend to make a lot of those =P
Don't worry about it mate, like I said, I had bits and pieces of it around my HD, I just had to tie them up together.
Enjoy!
Cool, let me know how it
Cool, let me know how it goes.
M.
How much do I owe you?! It
How much do I owe you?! It just saved me tons of time of tedious work... MUCH appreciated.
(p.s. the first line has a misspelling: "rollout condenseMats "Condese Materials" width:275" Should be "Condense" - damned typos!
I had worked on something
I had worked on something along these lines some time ago, so I just fixed it up a bit for you. Have a look at the attached script.
When you run it, it will list all of the materials in the scene by name on a treeView. If two are more materials have the same name they will be displayed as separate subNodes of the main material node. You can use the checkboxes to choose which one of the materials will be the "master", in other words, which material will replace the others with the same name. Disabling the checkbox at the top nodes will keep the script fro doing any changes to the materials with that name.
You can double click any of the subnodes to select every object in the scene using that material, this should help you to find which one to use as a master.
It was packed together pretty quickly, so there might be some bugs in there but give it a go and let me know.
Good luck.
Marco - I'm rebooting my
Marco - I'm rebooting my workstation then I'll give this a test. Thanks!
