disable xref scenes + save an incremental copy and enable the disabled xref scenes script :) by anubis and miauu thanks alot
Hey All,
I am trying to form an "xref scene based architectural workflow" but there s one faulty design that spoils it and the only way to solve it goes through two simple commands but i can not find it, and i am 0 at scripting either, incase someone decides to help with it.
i need to have the script disable all xref scenes , d some commands and enable them back.
--this line should disable every xref scene loaded into to the current scene
if maxFileName != "" then ( -- if the scene saved
max saveplus -- incremental file save
TheFile = maxFilePath + (trimRight (getFilenameFile maxFileName) "1234567890") + ".max" --remove trailing numbers
if doesFileExist TheFile do deleteFile TheFile
copyFile (maxFilePath + maxFileName) TheFile
) else checkForSave()
--this line should enable every xref scene loaded into to the current scene
so this saves a file but it will be removing all xref scenes before saving, and re-enable them forr the artist to go on.
btw, the middle code is written by Anubis ;) thanks to him.
thanks for any input.
yes i was surprised this time...
but now i believe it s done and very helpful already :)
Don't forget Anubis.
and absolutely
anubis:)
do some actions= ( if
testing right now.....
thanks already :)
okay great!
you made it seem like a piece of cake! but reality is different yes? i am still amazed at how simple, thing can be solved by scripting...
I have one more question, was there a way that i could possibly find the solution in some book or cd? like some book?
thanks again miauu, you are priceless too :)
