From\To selected objects - Get\Assign material
The subject must work with Slate editor via shortcut.
Could anybody help please?
1rv's picture
Works like a charm thank you
Works like a charm thank you so much Jahman, will definitely use it a hundred times per day.
Now may I kindly ask you to make "Select by active (SME) material" :) ?
jahman's picture
should work
macroScript SelectNodesByMaterial
category:"Jahman"
tooltip:"SME select nodes by material"
	fn GetSMESelection nodes:false =
		local index = sme.activeView
		local viewNode = sme.GetView index
		local SME_Selection = #()
		if index > 0 do
			local tv = trackViewNodes[#sme][index]
			for n = 1 to tv.numSubs do
				local ref   = tv[n].reference
				local _node = viewNode.GetNodeByRef ref
				if _node != undefined and _node.selected do append SME_Selection ( if nodes then #( ref, _node ) else ref )
		SME_Selection
	on execute do if SME.IsOpen() do
		local nodes = #()
		for m in GetSMESelection() do join nodes (refs.dependentNodes m)
		select nodes
1rv's picture
Made my day. Thanks a ton :)
jahman's picture
1rv's picture
I'd recommend to post them so
I'd recommend to post them so it won't get buried in Wanted sub-forum,
Best
jahman's picture
:D
Those who want something special should invest some of their time to google things up as I'm too lazy to test these scripts, upload 'em, make a description etc...
1rv's picture
One tiny and hopefully :)
One tiny and hopefully :) final request: when user hits a dedicated shortcut, could the script open SME if its closed?
jahman's picture
can't edit my prev posts, unfortunately
replace it with this:
on execute do
    if not SME.IsOpen() do SME.Open()
    local nodes = #()
    select nodes
1rv's picture
I get:-- Syntax error: at ),
When SME is closed I get an error:
-- Syntax error: at ), expected
-- In line: )
After my lame edit the mcr looks like:
macroScript SmePickMaterialFromSelection
category:"Jahman"
tooltip:"SME get material from selection"
on execute do
local nodes = #()
select nodes
What to fix?
P.S. Still works fine if SME is open
jahman's picture
link
