Has anyone got a script that will take a custon polygon mesh and output the code to build it in a max script. ie save out all the point and polygon data?
I am trying to make my own custom helper objects.
I have added a loop to check for any invisible edges and added a setEdgeVis to the string. see example below. I had to also assign the mesh to a variable so that I could reference it in the setEdgeVis function otherwise it wouldn't work! I still need to figure out how to add this as a nodeRef to the local scope of the pluginNode. I will keep trying! Thanks for being patient and all your help!
btw every geometryNode in max is essentially a trimesh (well at least the important ones )
why dont you try to modify the function i made to also add code for setting the edge viz for the new object? its simple and you can make your helper way dynamic by saving the string with the geoCode in a parameter of the node... that way users can either choose between preset helper shapes or pick their own geo shapes... dont forget that for that you need a temp global var to pass the nodeRef to local scope of the pluginNode
I tried modifying your code to this to add edge visibility:
(--mesh vertices:<array_of_point3s> faces:<array_of_point3s> --[ materialIDs:<array_of_integers> ] \
fn obj2Code obj =
(if isValidNode obj do(
local tMesh = copy obj.mesh
local nVerts = tMesh.numverts
local nFaces = tMesh.numfaces
local edges = #()
local verts = for v = 1 to nVerts collect getVert tMesh v
local faces = for f = 1 to nFaces collect getFace tMesh f
for f = 1 to nFaces do(
local facef = #()
append facef (getEdgeVis tMesh f 1)
append facef (getEdgeVis tMesh f 2)
append facef (getEdgeVis tMesh f 3)
append edges facef
local str = "(mesh vertices:"
with printAllElements true(
str += verts as string
str += " faces:"
str += faces as string
str += " edgevis:"
str += edges as string
str += ");")
tMesh = undefined
return str
))--END obj2Code FN
local tString = (obj2Code selection[1])format"%\n "tString
tString
this adds edgevis: to the code but its not recognised in the mesh command. Just gets ignored when executed.
Looking at the help it appears that you can only set the Edge viz with the following command setEdgeVis
btw you should only create the node in memory, that way you dont have to delete anything, afaik that fn doesnt work with a mesh but hey something for you to experiment with :)
try:
meshobj = createinstance pyramid()
to understand what i mean
fn obj2Code obj = ( if isValidNode obj do ( local tMesh = copy obj.mesh local nVerts = tMesh.numverts local nFaces = tMesh.numfaces
local edges = #() local verts = for v = 1 to nVerts collect getVert tMesh v local faces = for f = 1 to nFaces collect getFace tMesh f
for f = 1 to nFaces do ( local facef = #() append facef (getEdgeVis tMesh f 1) append facef (getEdgeVis tMesh f 2) append facef (getEdgeVis tMesh f 3) append edges facef )
local str = "local vertsArray = " with printAllElements true ( str += verts as string str += "\nlocal facesArray = " str += faces as string str += "\nlocal edgeVis = " str += edges as string ) tMesh = undefined
return str ) )--END obj2Code FN output = newscript() local tString = (obj2Code selection[1]) format "%\n "tString to: output )
--end
The code now outputs a new script in the following format:-
meshObj = mesh vertices:(for v in vertsArray collect v*size) faces:facesArray for face = 1 to edgeVis.count do for i = 1 to 3 do setEdgeVis meshObj face i edgeVis[face][i] theMesh = copy meshObj.mesh delete meshObj lastSize = size ) theMesh )
tool create ( on mousePoint click do case click of ( 1: nodeTM.translation = gridPoint 2: #stop ) on mouseMove click do case click of ( 2: (size = length gridDist) ) ) )--end
I have only tested it with simple geo, aslong as you give each helper a new name and a unique classID then it all works. I will try some more complex geometry next!
execute "(mesh vertices:#([0,0,51.5526], [-39.0721,-40.7057,0], [39.0721,-40.7057,0], [39.0721,40.7057,0], [-39.0721,40.7057,0], [0,0,0]) faces:#([1,2,3], [1,3,4], [1,4,5], [1,5,2], [2,6,3], [3,6,4], [4,6,5], [5,6,2]));"
evaluate that snippet î to see the result of what is so far..
the current function simply creates you a string that creates a mesh. to use it as code directly use the first line printed (a=createinstance code, mesh = a.mesh .. or something alike); otherwise use the string and execute it
doesnt have smoothing groups, matIDs or tVerts but you wont need that for a helper.
fn obj2Code obj =
str += " faces:"
str += ");")
tMesh = undefined
return str
))--END obj2Code FN
tString
nope thats correct,
just add a few lines to add that stuff to the string. if itd been that easy it wouldnt have been a good exercise, now would it?! ;)
Raphael Steves
Updated script
example:-
execute "(themesh = mesh vertices:#([-2.5,-2.5,0], [2.5,-2.5,0], [-2.5,2.5,0], [2.5,2.5,0], [-2.5,-2.5,5], [2.5,-2.5,5], [-2.5,2.5,5], [2.5,2.5,5]) faces:#([1,3,4], [4,2,1], [5,6,8], [8,7,5], [1,2,6], [6,5,1], [2,4,8], [8,6,2], [4,3,7], [7,8,4], [3,1,5], [5,7,3])); setEdgeVis themesh 1 3 false; setEdgeVis themesh 2 3 false; setEdgeVis themesh 3 3 false; setEdgeVis themesh 4 3 false; setEdgeVis themesh 5 3 false; setEdgeVis themesh 6 3 false; setEdgeVis themesh 7 3 false; setEdgeVis themesh 8 3 false; setEdgeVis themesh 9 3 false; setEdgeVis themesh 10 3 false; setEdgeVis themesh 11 3 false; setEdgeVis themesh 12 3 false;"
Hi gramx. This might do what
Hi gramx.
This might do what you want:
http://www.scriptspot.com/3ds-max/scripts/primitive-maker
Yes, its very similar to what
Yes, its very similar to what I am doing. cheers
[code] bla bla [/code]
Raphael Steves
edge visibility
Am I missing anything?
nope
nope
try:
Raphael Steves
Custom Mesh Helper Script
Not sure how to only create the node in memory. It seems to work OK so far! I adabted the code from this forum :- http://forums.cgsociety.org/archive/index.php/t-288270.html
It also seems that standard helpers can only be tri-meshes and only display as wireframe.
I have added edge visibility to the code otherwise you get a horrable triangulated mesh helper!
fn obj2Code obj =
local edges = #()
local facef = #()
append edges facef
tMesh = undefined
return str
)--END obj2Code FN
--end
local vertsArray = #([-2.5,-2.5,0], [2.5,-2.5,0], [-2.5,2.5,0], [2.5,2.5,0], [-2.5,-2.5,5], [2.5,-2.5,5], [-2.5,2.5,5], [2.5,2.5,5])
local facesArray = #([1,3,4], [4,2,1], [5,6,8], [8,7,5], [1,2,6], [6,5,1], [2,4,8], [8,6,2], [4,3,7], [7,8,4], [3,1,5], [5,7,3])
local edgeVis = #(#(true, true, false), #(true, true, false), #(true, true, false), #(true, true, false), #(true, true, false), #(true, true, false), #(true, true, false), #(true, true, false), #(true, true, false), #(true, true, false), #(true, true, false), #(true, true, false))
I then drop this code into the following ---mesh--- section of the scripted helper plugin:-
plugin Helper Mesh2Helper
classID:#(0x15424e9f, 0x5f189e30)
category:"Standard"
extends:dummy
local lastSize, meshObj, theMesh, lastpshape
parameters pblock rollout:params
size type:#float animatable:true ui:size default:1.0
rollout params "rt Helper Parameters"
spinner size "Size:" range:[0, 1e9, 1]
on getDisplayMesh do
if meshObj == undefined OR size != lastSize then
--------------------------------------------------------------- MESH---------------------------------------------------------------------------------
for i = 1 to 3 do
delete meshObj
lastSize = size
theMesh
tool create
case click of
2: #stop
case click of
)--end
g
lets get this going
execute "(mesh vertices:#([0,0,51.5526], [-39.0721,-40.7057,0], [39.0721,-40.7057,0], [39.0721,40.7057,0], [-39.0721,40.7057,0], [0,0,0]) faces:#([1,2,3], [1,3,4], [1,4,5], [1,5,2], [2,6,3], [3,6,4], [4,6,5], [5,6,2]));"evaluate that snippet î to see the result of what is so far..
have phun
Raphael Steves
How do you put your code in a
How do you put your code in a nice box like that?
