Yes,the bitmap name is changed,but the bitmap lost the link. The bitmap which is saved in disk is not changed name with it.
theMaps = getClassInstances BitmapTexture
for i in 1 to theMaps.count do
fileName = theMaps[i].filename
newFilename = getFilenamePath fileName + "\\map_" + i as string + getFilenameType fileName
if renameFile fileName newFilename then theMaps[i].filename = newFilename
this is someone help to change the bitmap name,but it can't change others except the diffuse channel....
So thanks for your help!
I test it...
Thank you for your help!
Thanks br0t! I will try it.
Thanks br0t!
I will try it.
