Selected vertex attracts it's nearest neighbor to weld into it.
Hello guys,
I am in need of a script:
If more than one vertex is selected, each selected vertex should attract to it the nearest neighbor. Only one vertex to be welded to the original vertex.
Would appreciate if anybody could help on this :)
tofoaso's picture
Thanks, it works although
Thanks, it works although again not for all vertices.. would be nice if there is a way to tweak it so it works for all.
If not doable I am still happy with what it does now though. Thanks :)
miauu's picture
Can you send me a scene where
Can you send me a scene where the script not works for some of the verts? You can select the verts, so when I open the scene I can see which verts hav e to attract iss neighbors and then I will see whic verts are not selected.
tofoaso's picture
Here is a small test where
Here is a small test where you have 6 verts selected and after the script runs, there is one selected:
File is max 2010
http://www.sendspace.com/file/dv3a5l
miauu's picture
And here is the script.
Don't forget to thanks to Branko.
	if selection.count == 1 and classof (curO = selection[1]) == Editable_poly then
		selVertsBA = polyop.getVertSelection curO
		if selVertsBA.numberset != 0 then
			channelIdx = 12
			polyop.setVDataChannelSupport curO channelIdx true
			vertsToWeldArr = #()
			for v in selVertsBA do
				vPos = polyop.getVert curO v
				neighborVertsBA = (polyop.getVertsUsingEdge curO (polyop.getEdgesUsingVert curO v)) - #{v}
				minDist = 1e9
				nearestVert = undefined
				for nv in neighborVertsBA do
					dist = distance (polyop.getVert curO nv) vPos
					if dist < minDist do
						minDist = dist
						nearestVert = nv
				append vertsToWeldArr #(v, nearestVert)
			if vertsToWeldArr.count != 0 do
				vertsArr = #()
				for i = 1 to vertsToWeldArr.count do
					polyop.setVDataValue curO channelIdx vertsToWeldArr[i] 0.12
					polyop.setVert curO vertsToWeldArr[i][2] (polyop.getVert curO vertsToWeldArr[i][1])
					append vertsArr vertsToWeldArr[i][1]
					append vertsArr vertsToWeldArr[i][2]
				polyop.weldVertsByThreshold curO vertsArr
				vertsToSelBA = #{}
				curOvertsBA = #{1..(polyop.getNumVerts curO)}
				for v in curOvertsBA where ((polyop.getVDataValue curO channelIdx v) == 0.12) do
					append vertsToSelBA v
				polyop.setVertSelection curO vertsToSelBA
				polyop.freeVData curO channelIdx
			messagebox "Select some vertices" title:"Invalid Selection"
		messagebox "Select only one editable poly object" title:"Invalid Selection"
tofoaso's picture
Works great! Thanks for the
Works great! Thanks for the script, its greatly appreciated! :)
miauu's picture
A slightly optimized version
			channelIdx = 12
			vertsToWeldBA = #{}
				minDist = 1e9
						minDist = dist
						nearestVert = nv
				append vertsToWeldBA v
				append vertsToWeldBA nearestVert
				polyop.setVDataValue curO channelIdx v 0.12
				polyop.setVDataValue curO channelIdx nearestVert 0.12
				polyop.setVert curO nearestVert vPos
			polyop.weldVertsByThreshold curO vertsToWeldBA
			vertsToSelBA = #{}
barigazy's picture
...more then sligthly optimized version :)
You know that the code will be optimized more if you use polyOp outside for-loop :)
Perhaps in this case there is no need for that. Can you try this:(not tested)
	if selection.count == 1 and isKindOf (curO = selection[1]) Editable_poly then
		selVertsBA = curO.selectedverts as bitarray
		if selVertsBA.isEmpty then (messagebox "Select some vertices" title:"Invalid Selection" beep:off) else
			local channelIdx = 12, vertsToWeldBA = #{}, vertsToSelBA = #{}
			local getVuE = polyop.getVertsUsingEdge
			local getEuV = polyop.getEdgesUsingVert
			local setVData = polyop.setVDataValue
			local getVData = polyop.getVDataValue
			local weldVerts = polyop.weldVerts  --polyop.weldVertsByThreshold
				vPos = curO.verts[v].pos
				neighborVertsBA = (getVuE curO (getEuV curO v)) - #{v}
				minDist = 1e9 ; nearestVert = undefined
				for nv in neighborVertsBA do (if dist = (distance (curO.verts[nv].pos) vPos) < minDist do (minDist = dist ; nearestVert = nv))
				vertsToWeldBA + #{v,nearestVert}
				setVData curO channelIdx #{v,nearestVert} 0.12
				--curO.verts[nearestVert].pos = vPos
				weldVerts cur0 v nearestVert vPos
			--weldVerts curO vertsToWeldBA
			for v in 1 to obj.numverts where ((getVData curO channelIdx v) == 0.12) do vertsToSelBA + #{v}
			curO.selectedverts = vertsToSelBA
	) else (messagebox "Select only one editable poly object" title:"Invalid Selection" beep:off)
barigazy's picture
				vertsToWeldBA + #{v}+#{nearestVert}
barigazy's picture
barigazy's picture
Hey Kostadin
Why me? I didn't do anything.
All credits goes to you. You did exelent job. :)
Anyway how is your son, do you feel better?
