Rotate pivot to Targeted Obj
How would I create this same script but without the hassle of using the point object and just modifying the actual objects pivot?
I'm trying to rotate a pivot to look in the direction of a target with an axis constraint.
To test just create a bunch of boxes on different position in 3d space and then create a sphere at 0,0,0 using that as the target.
targetObj = $Sphere001 sel = selection as array for obj in sel do ( --pivotLookAt obj $Sphere001 local dummyPt = point() dist = obj.pos - targetObj.pos dist = normalize dist upVec = [0,0,1] dp = dot dist upVec t = acos dp c = cross upVec dist c = normalize c dummyPt.transform = obj.transform dummyPt.dir = c dummyPt.pos = obj.center in coordsys local rotate dummyPt (eulerangles -90 0 0) in coordsys local rotate dummyPt (eulerangles 0 0 -90) worldAlignPivot obj theRot = dummyPt.rotation in coordsys local obj.rotation *= theRot obj.objectoffsetrot*= theRot obj.objectoffsetpos*= theRot delete dummyPt )
pseudoCode:pivot.angleAxisRo
pseudoCode:
pivot.angleAxisRotation axis:normalize(objectPoint3-pivotPoint3) angle:acos(dot (normalize (objectPoint3-pivotPoint3)) (normalize (PivotZVector)))
that should do it ;)
edit: "I'm Batman"
Raphael Steves
replacing variables
Would this be used in place of the PivotZVector Batman? PivotZVector = [0,0,1]
objectPoint3 = (object to which pivot will be pointed towards).position
pivotPoint3 = (currently selected object wishing to change).position
John Martini
Digital Artist
