to get full path in listbox
this is good scripter source .
that is directory list box script.
when i select list box item ,i would like to know full path name .
first of all , pls make directory in c
c:temp - a - aa
- b - bb
- c - cc
- d - dd
------------------------------------------------------------------------ materialib_path = "c:\\temp\\" paths_array = #() paths_array_list = #() current_files = #() bitmap_count = #() fn matlist a b = () fn get_info = () fn build_paths path count = ( count = count + 1 append paths_array path append paths_array_list count dir_array = GetDirectories (path + "*") if dir_array.count > 0 then ( for i = 1 to dir_array.count do ( build_paths dir_array[i] count ) ) return paths_array ) fn makeoffsets li = ( list = deepcopy li for i = 1 to list.count do ( ins = "" level = 1 while level < paths_array_list[i] do ( level = level + 1 ins = ins + " " ) list[i] = ins + list[i] ) return list ) fn format_list list = ( r = deepcopy list if r.count != 0 then ( for i = 1 to r.count do ( l = r[i] res = filterString l "\\" r[i] = res[(res.count)] ) ) return r ) fn format_extensions list = ( r = deepcopy list for i = 1 to r.count do ( r[i] = (filterString r[i] ".")[1] ) return r ) rollout materialib_rollout "111_materiaLIB v0.2" width:300 height:910 ( listbox lbx1 "categories:" pos:[2,24] width:160 height:55 items:#("ddd", "eee") on materialib_rollout open do ( matlist 1 materialib_rollout paths_array = #() build_paths materialib_path 0 lbx1.items = makeoffsets (format_list paths_array) ) on lbx1 selected sel do ( matlist sel materialib_rollout paths_array = #() ssss = #() build_paths materialib_path 0 lbx1.items = makeoffsets (format_list paths_array) ) on lbx1 doubleClicked sel do ( ) on lbx2 selected sel do ( ) on lbx2 doubleClicked sel do ( ) ) fn matlist sel materialib_rollout = ( try ( ) catch ( ) ) fn get_file_count file = ( ) fn get_info sel materialib_rollout = ( try ( ) catch ( ) try ( ) catch ( try ( ) catch ( ) ) ) createdialog materialib_rollout style:#(#style_minimizebox, #style_titlebar, #style_sysmenu)
really thank you
really thank you again
work is good
@dussia
Try to respect forum rule
