I need a little script to delete last MatID(Mesh)
Hello, i spent a lot of time on making this stuff and first time i release it, but second i couldn't make it again,
to delete last MatID(mesh) by 1 click, can someone help me with this ?
IT's a simple script when you select a mesh and press button - it deletes last MaTID(mesh).
P.S.
And if it possible http://dfiles.ru/files/owsepv1vr to modifie this script(its .psk file importer) and add to it a possibility to insert special mesh(On the importing model), while importing the file, with position controlling rulers.
Hey, how do you setup "post below" hyperlink. Very cool
[link to this post is here]
Each post has link in it title ;-)
No "append" is fester from
No "append" is fester from "collect" probable because for append method you already have defined array and for collect you build array on the fly.
Also is better to store mesh fn in local variable before use it multiple time (in for-loop or while-loop etc..).
By the way, is there easy way to get bigest mtlID number of geometry object.
I think that's poly method is more efficient (numFaces count is twice lower).
LOL
I'm sure that I done some test in the past to end with such conclusion that Collect is faster than Append :) Anyway, will test once again (some day).
Storing a function in variable,.. ya I know that helps in case the function is a Struct member, like meshOps for example, but not thought to test that for other (stay-alone) functions. So, it's help for them too?
As for easy way to get bigest mtlID, well,.. it's what I use in my function (for..if..x>y..y=x), at least don't know better :) We have #materialIDs named-prop in Mesh Constructor, but we cannot access it after that (on existing mesh), so sad, and the great ADSK is so lazy to make that property script-visible. If were exposed then all to code w'd been just this:
amax m.materialIDsbut... :)
Hey Panayot,
I know. I agree with you (laziness is a bad habit) :).
Also I wonder when Phyton become part of max. Like in Maya or Softimage or Cinema4d or Blender or ... 10 more softwares. .net is very useful but phyton ...
Yes i tested it. Also i check
Yes i tested it. Also i check time and memory leaking and you have better solution for sure. Memory leak is the main problem in this aproch.
Thx you very much!
Thx you very much!
But it gives me error
http://i.imgur.com/HdlP72N.png
Sorry i forget to replace "$" with "obj" variable.
I fixed the code try now.
Try to avoid objects that have only one mtlID
sorry but its still gives me
sorry but its still gives me error.
http://i.imgur.com/oBbylT7.png
are you in Max 9 or below?
if so, there no
appendIfUniquefunction, at least until install AVG (Avguard Extensions).my recent MAXScripts RSS (archive here)
