Walls with dimensions name?
I spend a lot of time creating walls, measuring and renaming. I just wanted to create lines in top view and execute a command that adds 10 Outline 320 extrude mesuare the length of the line i created and rename object:
"Wall X, 10, 320" are the values that I use most.
(if there is a text box that I could imput all value and create, would be perfect, but it would probably be hard to create, I think)
thanks guys
Thanks barigazy, but I would
Thanks barigazy, but I would prefer that you do it :)
Come on man! :)
The code is very easy. It is harder to write code for UI here then actual function for GO! button :)
hahahahhah !! the time that I
hahahahhah !! the time that I miss, I'm always busy with work!!! Is hard find the time to make these small changes :)
Same here :) My work is not mxs related so ...
Definitely perfect!
I separate my objects by edge color, you helped me more than enough. The name is exactly the right way. Many thanks again. You have an impressive speed of creation. Congratulations for the excellent work, I'm sure you've helped a lot more people that have this problem! Thank you very much, for helping me the second time! Peace bro!
Yup. I definitely lost the count :)
I added few more options:
-- support for multiple objects
-- reverse knots order of selected spline or all "attached" shapes
-- 2 modes: use offset shape and extrude modifier method or combo with extrude and shell modifier which is more flexible solution for sure
-- created modifiers can be instance or copy
This is hot!
I enjoyed the new functions, this script will save me much time. It would be nice if he could group the wall at the end with just the name that I put, without the number "002" or "003" etc. Thank you for facilitating my work! You guys are great!
Great job barigazy :)
I hope this can help. The
I hope this can help. The only requirement (for now) is that you must select ONE splineshape at a time. The splineshape can be closed or open. If you find error, please let me know!!
