Submitted by artrender.info on Tue, 2013-05-14 09:07
I have a house in 3d and a background in it! I want to create scene states for every camera, so when I switch to any of them, I would see automatically the changes according to it's state! Any ideas?
You can't acess local variable d. You need to put local d outside event ei. function. Or even better why not add all inside "on btn2" event
on btn2 pressed do(
objTMData = attributes objData
local objTMS = for o in objects collect DataPair o o.transform
fn setObjTM arr =
(for i in 1 to arr.count where isValidNode arr[i].v1 do arr[i].v1.transform = arr[i].v2
local d = FreeCamera()
custAttributes.add d objTMData
on btn2 rightclick do(
ca = custAttributes.get d objTMData
ca.setObjTM ca.objTMS
I wonder, are you just one person - barigazy, or a big team of experts! You answer 24h/24h to our question! Do you sleep, do you eat? Or you have made a script for all this things that take too much time! Share with me if you have such scripts? A script - not to go to the shop, not to cook and so on!
fn getGrandParentName obj =
local pn = obj.name
-- repeat while there are more parentswhile obj.parent != undefined do(-- follow link out to next parent & pretend its name
obj = obj.parent ; pn = obj.name
) ; pn
grandParentname = getGrandParentName $
----------------------------------------------to check if obj transform is animated
$[3].isAnimated
fn getAllChildren obj =
local o = obj,childArr = #()while o.children[1]!= undefined do(
append childArr o.children[1]
o = childArr[childArr.count])
childArr
I think, I will have for every camera from the listbox, rightclick/ in a popup window- button pick object you want to transform => pick the object => check if it is animated and then if it is parent-=>if not allow user to move/scale/rotate that object! a button-save transform, dropdown lsit with objects that are linked to that camera and with the option to remove any of objects from the list! This way, the script will do it's job!
I need of course much more time to do that, but I will try to make it later! I appreciate very much your time, Barigazy!!!!!!!!!!!
but may be we have to give possibility to select from non animated objects and nonparent only, because we change coordinates of them for given cameras!
Thank you Barigazy! It's a blessing to have you here! You help us a lot! May be, that's why 3d max does not contain scene states for object transforms - because of animation of the object!
-- test with this:-- create first some random objects in the scenes-- define custAttributes and assigne to some object in this case free camera
fn setObjTM arr = for i in 1 to arr.count where isValidNode arr[i].v1 do arr[i].v1.transform = arr[i].v2
d = FreeCamera()--assigne to camera
-- now you can test by changing position and rotation of scene objects-- and finaly run next two lines
-- this is not good way if some objects are parented or animated
thx
Yup. I'm human :) No team just me.
Barigazy, tell me please
How to check if an object is parent?
Check
$.children.count --if more the zero then this is the parentbga
some useful fn's
thx
great
this is the recursive code from mxs help
