I'm having to import over a thousand 3ds objects into max, each objects material (TGA) has an alpha channel. All I need to do is the Copy Diffuse slot to Opacity slot and set the mono channel output to alpha.
I've been trawling scriptspot for ages, there are lots of Material scripts, but I can't find one that will do this simple task.
I get this from listener.....
meditMaterials[1].opacityMap = Bitmaptexture fileName:"C:\Program Files\Infogrames\Grand Prix 4\Tracks\my_track\Import Full Track To Max Test Track\melborne2001\maps\melborne2001\page_335.tga"
meditMaterials[1][#Maps][#Opacity__Map__856__page_335_tga].monoOutput = 1
But I can't figure out how to just use it on the selected slot, or preferably all slots in the material editor, basically I need that little bit of script to work without looking for the specific tga image name.
btw I'm a Maxscript Luddite...go easy on me ;) I@m hoping script already exists
tia
Comments (15)
Cool , works a treat once more, many thanks dude.
...but I did have to change the last line to mat.opacityMap.monoOutput = 1......again... ;)
@ juumax
full code is....
for Obj in objects where isValidNode obj do
local mat = obj.material
if superClassOf mat == material AND isproperty mat "diffuseMap" AND classOf mat.diffuseMap == bitMapTexture do
mat.opacityMap = copy mat.diffuseMap
changed the last code i posted..
it now checks if the diffuseMap property is present..
currently it uses isproperty .. if that dont work try hasProperty
have phun
Hmm, I just started using this in 2011 and the listener spits out this...
-- Error occurred in obj loop; filename: ; position: 145; line: 5
-- Frame:
-- obj: $shadow test
-- mat: Standard 14:Matte_Shadow
-- called in anonymous codeblock; filename: ; position: 258; line: 10
-- Frame:
-- Unknown property: "diffuseMap" in Standard 14:Matte_Shadow
-- Frame:
-- obj: $shadow07
-- mat: Standard_11:fR_Matte_Shadow
-- Frame:
-- Unknown property: "diffuseMap" in Standard_11:fR_Matte_Shadow
seems it doesn't like matte shadow materials in the scene ?
even when I'm running it on a standard material in the number 3 slot with no matte shadow......weird. Maybe when the check finds a matte shadow in the diffuse slot anywhere in the scene it freaks out.
What's your listener saying when you run it ?
Hey I am trying to run this script in max 2010 and I cant seem to get it to work. Do I have to rename my objects in a certain way? I run the script and nothing happens. I have a checker material in the diffuse of a standard material.
I quiet new to maxscript so I dont really understand why, I am trying to do a similar thing as the OP.
yeah borpheus had a spare ;)
(not a typo)
Awesome...I like fail safes, prevention is better than cure ;) Thanks I'll see if I can break it........
code was this ...... (from 1st post)
which was working but for some reason stopped, (or worked sometimes and not others) but I needed it to work on the alpha, so I added this......
Obj.mat.opacityMap.monoOutput = 1
So the final code is....
if superClassOf mat == material AND classOf mat.diffuseMap == bitMapTexture do
...which works a treat.......I take it this code runs some checks first ?..., when you post code....i see this.......
gHFGHfghfghfgH&&%&9%^98%^*%^*5^*%^%$&45&4^8%&(5^7%^746*&(%6rtUrTRHJrfJRjRU %^*%76856*58%^8%685^8%6&£$5"FHR^846jFGmJ67(%^urtHR^&8%^*58%*%^8%6*4^&$5&%7 63%$74YRTh^%8&5967)&0^7(5^$%^*&$%8$*4%8$6(%7)6&*0-^8^7(46$£%&37$*5^95&0^)6
if you see strange symbols only .. how come you got the code i posted there? 😉
and yeah it runs some checks first.
-normally you'd check if the object has a material, then if the material has a diffuseMap and then if that mathes the class your trying to work with
-faster way is to check the classes of the values ;) cuz if something is undeFinedClass it aint a bitmapTexture or a material
I was just about to say that......but you beat me to it
...seriously tho' it feels more refined...you obviously took the red pill 😎
o.0code plsif its the small
o.0
code pls
if its the small block up top then here it is again with failSafes
Now says -- Unknown property: "material" in undefined :/
replace mat with material
Hmmm... I've come back to using this script in Max 2011 and now I get a
-- Unknown property: "mat" in undefined when I run it, I can't figure it out....can anyone help?
thx
:D sry my fail, dont read your post correctly
That didn't, but it was easy for me to change the last line to this...and it works perfectly :)
Many thanks, it's a big help...and sort of my first ever script ;)
Don't know if this solves your problem. Copies the diffusemap to opacity channel and set the output-invert to true
