Hi, my situation is this:
I have many files with old network path to fix (many textures).
Would a script that automatically, when opening the file, change only part of the network path, so as to associate automatically the texture, and without having to search again.
example:
old path. "\\192.168.0.300 \ .... bla bla bla"
new path: "\\192.168.0.200 \ ..... bla bla bla"
The script should do this:
find (only this path part)"\\ 192.168.0.300 \"
replace with: "\\ 192.168.0.200 \"
A bit like the "retarget common root" Asset Tracking ", but do it automatically when you open the file.
(I apologize for my English)
Regards.
Comments (8)
hey,
Try Library Track/Relink - it works for multiple max files.
http://www.scriptspot.com/3ds-max/scripts/library-track-relink
To change beginning of paths (drive letter, network location):
- Select max files
- Choose Show Assets
- Select all with "\\192.168.0.300 \ .... bla bla bla"
- Choose Set Path from right click menu
- use second option - Remove 1st "\...."
- type new \\192.168.0.200
- press Apply
If your files are saved with older version of max - first select them and choose Resave to current version (right click menu)
Its not automatic on open, but you can re-path whole old library / projects to new location
Cheers,
Pixamoon
Hi pixamoon,
thanks for the advice.
I tried it and then purchased, useful scripts, definitely will save my time.
I have a request, it would be possible to do the same thing for the material library.mat ?
Upgrade part of the old path with a new one and resave?
Tanks a lot.
Yes, I just tested with .mat library files. It works. I'll upload new update today or tomorrow.
There is also auto-relink function if assets are still missing.
Thanks for your purchase and new suggestion!
Pixamoon
oki, please try new v0.51
It should work with multiple .mat files
Let me know if any bugs
Hi Pixamoon,
awesome, tried and it works perfectly, just what I needed.
Very thanks, really appreciate.
Cheers,
notrolee.
You're welcome :)
v0.52 has also fix if you need to resave older .mat lib files
Cheers,
Pixamoon
Thanks Pixamoon
always better.
Question, it would be possible in the future to be notified of any updates to the script by email.
So stay up to date .... and maybe also for other scripts.
thanks a lot
Nitrolee
Sure, no prob, please send your email and turbosquid username to pixamoon@gmail.com
I'll add you to the list.
I'm planing to do newsletter with scripts updates too, but this bit later.
Next updates of Library Track/Relink coming with:
- save settings / favorite folders to search in
- quicker auto relink
- resize / convert bitmaps
- collect assets from multiple max files
- and more :p
And of course I'm always open for new suggestions.
Best,
Pixamoon
