Maxscript dotnet
Hi Guys,
I'm working on a script which uses a dotnet form for the UI. One of the elements is a ListView. When trying to get it to select one of the items I get an error. I'm basing a lot of it around:
http://scriptattack.com/snippets/snippets.html
Although I have to call functions like this:
fn Shot_lb_Get Shot_lb evnt =
hit=(Shot_lb.HitTest (dotNetObject "System.Drawing.Point" arg.x arg.y))
row=hit.item.Index
dotnet.addEventHandler Shot_lb "MouseUp" Shot_lb_Get
Does anyone have an idea why it fails?
John
or use base64 code ;)
http://www.scriptspot.com/forums/3ds-max/general-scripting/solved-logo-i...
select in ListView
Do you want to select by script one item/line of listView or get selected line/lines?
Like in http://www.scriptspot.com/3ds-max/scripts/bitmap-tracking-resizing
or http://www.scriptspot.com/3ds-max/scripts/library-track-relink
to get selecttion count:
lv_objects.selecteditems.countto get first selected item:
lv_objects.SelectedItems.item[0].subitems.item[0].textto select 1st on the list:
lv_objects.Items.item[0].selected = truewhere lv_objects is dotnet ListView
Hope it helps
Pixamoon
