3ds Max | All
Align Points
1 vote
Free Tool
This tool aligns selected mesh vertices and spline points.
With splines you can align bezier vectors too.
available here
miauu's GridAxisPainter
0 votes
miauu's GridAxisPainter allows you to set different colors for the major X, Y, and Z axes in any viewport.
For more information, click here: miauu's GridAxisPainter
Corona Material Automator
4 votes
ECamera2Batch
1 vote
ECamera2Batch – Professional Camera Batch Render Manager for 3ds Max
Streamline Your 3ds Max Rendering Workflow with Intelligent Camera Processing
ECamera2Batch is a powerful MaxScript tool designed to revolutionize how you handle multiple camera renders in Autodesk 3ds Max. This professional-grade solution automatically creates batch render views from selected cameras while intelligently parsing camera names for custom render parameters.
Group to EditablePoly
4 votes
This script is intended to convert group into editable Poly (It keep editable mesh as editable mesh when an editable mesh is in the group).if you have multiple groups selected it will create multiple editable poly(or mesh) objects ( one object per group). It support nested groups (group within group).the script has no interface, it's just a button, here is the default icon , once installed you just need to have one or multiple groups selected and click the button and that's it, no fancy options.
miauu's CameraCycler
3 votes
miauu's CameraCycler allows you to cycle forward and backward through all cameras in your scene using two hotkeys.
Download it here: miauu's CameraCycler
miauu's Drag&Drop Pro
1 vote
miauu's Slate Material Cloner
1 vote
3DS Max - Plugin Update - CopyPasteDWG V1.5
1 vote
*Description:
This plugin allows the user to copy paste geometries from AutoCAD into 3DS Max.
The plugin works with multiple opened AutoCAD files. It recognizes the last copied objects.
The script offers many filtering options for the imported objects like:
1-Removing the prefix "Layer:" and this will make it easier to select objects by name.
2-Removing any material applied to the imported objects.
3-Removing the Block/Style Parent hierarchies. (You might encounter name LinkComposite, it's the same thing.)
4-Selecting the imported objects when importing is done.
PickMaterial
2 votes
This script is intended to pick material in viewport and send it to material editors (both Slate and Classic),it will automatically open material editor if it isn't opened yet.
If you pick a Multi/Sub-Object material it will load the material applied on the picked polygon rather than the all Multi/Sub-Object material.
As long as the script button is highlighted in blue , you can continue picking materials
To exit the script you can either right-click or click the script button
Syndicate content
