3ds Max | All
miauu's Layer States
0 votes
Webp to jpg
2 votes
This is not a 3dsmax script but a stand alone application.
Double click the .exe file, browse to the desired folder (you won't see the files while browsing), press convert images.
All webp files in the folder will be converted to jpg
edit: It might be flaged as trojan by your anti virus,it is false positive. I'll try to find a solution to this annoying problem.
Domino Rigger
30 votes
Easy and Procedural Domino Animation Tool for 3ds Max
Book Rigger
166 votes
Now Supports the Latest 3ds Max Versions with Improved features!
One-click page turns, ready to animate.
Make believable book and page animations in seconds. Book Rigger builds a full page-turn rig for any page count, gives you intuitive controls for flipping and shuffling, and supports single or double-sided materials. Drag, drop, rig, animate.
Mesh Cleaner
1 vote
A 3dsMax Script for Cleaning Objects Topology.
*Please Save your Work before using the Script (just in case!).
miauu's PinMyFiles
0 votes
tPDatasViewer
2 votes
'tP DataViewer' for faster feedback than default debug mode.
Support Group filtering and groupSubtree selection.
miauu's Transfer Edges: Poly <-> UVW
3 votes
3DS Max [Plugin Update] Multiple Sections v1.5
0 votes
In this version, I added the ability to clean the sections of unnecessary vertices. This feature works with the sections created by this plugin, and you can also use it with splines in the scene. Please watch this video to the end to learn about this new addition.
To learn about all the plugin's features, you can refer to the demo video for the first version:
https://youtu.be/4HX5wssIqSw
But download and install the updated version from here.
miauu's Select by visibility
3 votes
With miauu's Select by visibilit you can:
Syndicate content
