3ds Max | All
Set Edge Length
0 votes
Description:
  Set selected edge length, total chain length, round edge lengths, increment/decrement selected edge groups,
  space selected chains equally, and align selected chains without spacing.
BOA Ref
3 votes
Quickly paste image references
from your clipboard directly to your 3d scene.
Powerful tool for artists that use references workflow.
BOA Ref Banner
More information on: https://assets.boxofapps.com/tools/boa-ref
*Alpha and Beta versions are Free to use on commercial projects.
Nuke'Em (Max to Nuke Exporter)
3 votes
Just paste the output straight into the DAG and have your 3D scene ready to render.
Exports Cameras (Standard, Physical, Brazil 2 and VRay), Objects, Animated Objects and Helper Objects.
Automatically brings in diffuse and opacity colors/map.
Creates a Nuke Script automatically.
Outputs Chan files.
Chan object and camera animation import into Max from Nuke.
Outputs Custom Frame Ranges for Transform or OBJ Sequences.
Single Object Utility buttons (export a single OBJ/3D-Transform in one click).
Nuke and After Effects 2D corner pin export.
Correct VRay Physical Camera FOV export.
Outliner2-SF
2 votes
Outliner2-SF - the revived 3ds Max Scene Manager is ready !
The initial release of my 3ds Max 2027 compatible Outliner build is here.
I’ve just published a revamped and updated version of the well-known Outliner scene manager for 3ds Max. The original Outliner by P.J. Janssen has been a reliable tool for many years, but it has stopped being compatible with newer 3ds Max versions many years ago (starting around 3ds Max 2015)
* 3ds Max 2016 → 2027 support
* Native 3ds Max Layer Hierarchy (no whacky Custom Attributes)
* New Scene Explorer–style iconset
UnwrapUVW Editor AutOOpen
4 votes
v.2.3 Now, when you run Unwrap UVW_Editor_AutOOpen on an object where Unwrap already exists anywhere on the stack, it will become active in the editor. A new modifier will only be added if there is no modifier at all.
Теперь при запуске UnwrapUVW_Editor_AutOOpen на объекте, где в любом месте стека уже есть Unwrap, именно он станет активным в редакторе. Новый будет добавляться только если модификатор отсутствует вовсе.
Script makes. Скрипт делает
1) Assigns unwrap UVW. Назначается unwrap UVW
-Deleted-
0 votes
MultiSub Organizer
3 votes
MultiSub Organizer is an advanced tool designed to organize large Multi/Sub-Object materials alongside their linked Face IDs within EditPoly or EditMesh
Key Features:
Synchronized ID Updates:
- Apply a new ID to both the material and the linked Face IDs simultaneously, ensuring your geometry and shaders stay perfectly in sync.
Favorite Scripts
32 votes
v1.39
New: Recent / History of last picked scripts (only Full version)
Automatic Scripts Menu for .ms and .mse scripts.
From Office Network location, Local or Dropbox ( same scripts on every machine and all max versions )
Inner Chamfer
4 votes
Inner Chamfer (maxscript) is the tool for creating chamfers in the inner corner topology of Editable Poly objects. 3ds Max’s vertex Chamfer works only for outer corners, so this tool complements it by making it possible to create chamfers in inner corners.
Update: 1.1.0
Sub Object Constraints Improved
2 votes
Description: Slide verts & faces along edge paths. Similar to the standard constraints, but works in both directions.
Syndicate content
