3ds Max | All
PixPatch AI
0 votes
PixPatch AI: Fix Renders Instantly inside 3ds Max
Stop wasting precious time on minor re-renders or tedious Photoshop fixes.PixPatch AI connects 3ds Max directly to Google's world-class Gemini AI, allowing you to modify, enhance, and fix your renders in real-time without ever leaving your viewport. Whether you need to add people, swap materials, or fix a small glitch, PixPatch AI handles the heavy lifting directly from your Frame Buffer.
MatSnap AI
0 votes
MatSnap AI - AI Material Generator
MatSnap AI is an AI-powered script for 3ds Max that turns screenshots, photos, and text prompts into fully seamless, high-resolution PBR materials in seconds. It bridges the gap between AI texture generation and 3ds Max, allowing you to create production-ready materials without ever leaving your workflow or searching through texture libraries.
Fix Poly Topology (Problematic long edges on window frames)
0 votes
Work smarter, not harder! This script in 3ds max allows you to fix these edges in one click. The script uses turn to poly modifier, so I recommend detaching problem window frames before using this script. Category - Maketer
MW Tiles - Procedural OSL Tile Map Collection for 3ds Max
1 vote
MaxBatch - Advanced Batch Render Manager for 3ds Max
0 votes
ForestPack Manager Cover
MaxBatch is a comprehensive batch rendering utility for 3ds Max. It provides a structured interface to queue and manage multiple rendering tasks, whether you are rendering multiple cameras within your active scene or processing a list of external .max files sequentially. It is specifically optimized for V-Ray 7 and Corona 14.
ForestPack Manager
0 votes
FPManager is a powerful MaxScript utility, specifically designed to optimize workflow when using iToosoft Forest Pack in 3ds Max.
Key Features:
Global Scene Management: Instantly select all Forest Pack objects in the scene (visible or hidden) and force a global refresh/rebuild to update distributions.
Corona Elements to Photoshop Automator
0 votes
Corona Elements to Photoshop Automator (Drag and Drop MZP installer/uninstaller).
This tool automates the process of saving all Corona Render elements and stacking them as layers in Photoshop immediately after a render finishes. Drag and drop the MZP into 3DSMax viewport, it will launch an install/uninstall window. Installs to Main UI -> 'Custom Tools' in the Customise User Interface.
GeoSplat - Map Location to Gaussian Splat PLY Automator
0 votes
GeoSplat Studio v6.1 Automated aerial 3D Gaussian Splat pipeline for Windows.
Pick a location on the map. GeoSplat Studio autonomously captures orbital frames from Cesium's 3D globe, runs COLMAP Structure-from-Motion, trains a Brush 3DGS model, and outputs a .ply file ready to import into 3ds Max 2026 / Corona 14.1.
ms Spline Trim
1 vote
Finally!
A powerful 3ds Max modifier
for trimming and randomizing splines
with full control.
ms Spline Trim - a must have plugin for 3ds max. It's an advanced shape/splines modyfier that allows you to create stunning motion effects is seconds - like the one you know from After Effects - Stroke, Saber or Vegas effects. Trim, Offset and Randomize your shapes, texts and paths. Add an extra touch to your animations.
Perfect for:
- texts
- motion graphics animations
- procedural patterns
- abstract spline setups
- cables & wires
- fences & rails
One-Step Copy & Relink (Bitmap Path Manager)
0 votes
One-Step Copy & Relink is a workflow utility that consolidates two tedious texture-management tasks into a single operation. It scans your scene for all bitmap-based maps — standard BitmapTexture, VRayBitmap, and VRayHDRI — then copies the source files to a destination folder of your choice while simultaneously relinking the materials to a different target folder using a new file extension.
Syndicate content
