3ds Max | All
UniRemover
24 votes
And all this works by single button
v.10.61 изменена для быстродействия функция удаления рёбер вместе с вершиной. the function of removing edges along with a vertex has been changed for speed.
v.10.6 Fixed bug of convert to poly (Previously, on highpoly objects, after the conversion, there was a terrible braking in vertex mode)
CrossHairCursor
1 vote
CrossHairCursor
3ds max has a CrossHair Cursor Toggle
The script was deleted
Directories
5 votes
v.1.24 Added Current File folder
v.1.23 All vesies of Max
Handy script for open folders 3dsMax.
Rather, the idea is important.
The path and name of the buttons can be changed to other
Удобный скрипт для быстрого открытия папок 3dsMax.
Здесь скорее важна идея.
Пути и названия кнопок можно поменять на другие
miauu's Statistica
0 votes
miauu's Statistica offers you a lot more statistics information related to your current selection and entire scene.
The statistics are separated to 4 sections which you can customize by turning on and off options in the Statistica user interface.
UniConnector
41 votes
All this works by single hotkey.
Find Any Texture
2 votes
This script helps you find textures or Maps nodes or objects by Map or texture file name. It will also help you find Maps with missing textures or empty file path. It works for any 3dsmax native Maps , Corona Maps and Vray Maps.
update1.7: Bug fix when searching for texture by its name, on vraybitmaps.
update 1.8: Bug fix, it was crashing when using"exact match" on vraybitmaps.
update 1.9: Bug fix, Search Empty Bitmap was crashing on vraybitmaps
StrTools
14 votes
Quick tools in one place. Dockbar!
GLB2OBJ
2 votes
This is a small application to convert glb to obj
extract the zip file anywhere. launch glb2obj.exe file, choose one or multiple files ,then an output folder and press "Convert Files".
to import objs into 3dsmax you should use my script "ImportObj" http://www.scriptspot.com/3ds-max/scripts/importobj ,It will import PBR materials and handle multiple parts objects.
Update 1.1: Added glTF support,a better texture file naming for PBR textures,and a new UI.
FurniList 2 free
0 votes
  • FurniList LITE v.2 – Smart Dimension Exporter for 3ds Max
  • FurniList LITE v.2 is a lightweight yet powerful utility designed for furniture designers and 3D artists who need to extract manufacturing dimensions directly from 3ds Max into Excel.
Copy Paste DWG
47 votes
 New - Crop option to crop unnessesary parts of imported blocks etc
This is another simple script to speed up some everyday modeling work....
Just to simply Copy Paste selected from AutoCAD or DraftSight to 3ds MAX
It copy only selected, so its easy to split dwg to separate objects (elev from plans etc)
Syndicate content
